Author Topic: What Is This Connector Called?  (Read 1777 times)
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« on: Mon, 16 September 2013, 16:56:26 »
My google-fu is clearly lacking and I've been unable to find a specific connector that I am looking for. So I figured I'd do what I do when it comes to keyboard conundrums and see if the GH Collective could shed some light.
UPDATE
No sooner do I post this and then I find something close - "7-pin S-Video" That's the closest thing I've been able to find thus far. If anyone has anything more definitive, please let me know.  :thumb:
Link to larger version
It is similar to a PS/2 connector in style and shape, but this is the end of a video cable dongle and not a keyboard. We're looking to find the female version of this connector for a non-keyboard related project, but can't seem to find it.
By definition, I'd call it a 7-pin mini-DIN, but it has a different layout that what you typically see with 7-pin connectors.
Any suggestions?
« Last Edit: Mon, 16 September 2013, 17:08:16 by mashby »
Re: What Is This Connector Called?
« Reply #1 on: Mon, 16 September 2013, 16:58:55 »
« Last Edit: Mon, 16 September 2013, 17:04:37 by SpAmRaY »
Offline MTManiac
« Reply #2 on: Mon, 16 September 2013, 17:08:17 »
you read that and typed a response with 4 different links in 00:02:29...  :eek:
well done spamray well done indeed /camping skillz
Offline mashby
    • Mashby
« Reply #3 on: Mon, 16 September 2013, 17:13:16 »
Super fast response SpAmRaY. Thank you!
Yeah, it appears to be a 7-pin S-Video connector and I think we found a source for the female connector at this link.
Offline RabRhee
« Reply #4 on: Mon, 16 September 2013, 17:15:36 »
Some on Amazon as well -
http://www.amazon.com/Gino-Metal-S-video-Female-Sockets/dp/B00CQNW2CI/ref=sr_1_1?ie=UTF8&qid=1379369543&sr=8-1&keywords=Female+DIN+7+Pin+S-video+Sockets
Edit. 4 in stock, probably all the same seller :)
-Life is good-          Crafting: |  KeychainsMore.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline kaotikb
« Reply #5 on: Mon, 16 September 2013, 23:44:37 »
Its a 7 Pin s-video connector. 7 pin sockets can be compatible with 4 pin s-video cable.
I use to have an Ati Radeon video card that had a 7 pin s video that i used to connect to the old crt tv.
« Last Edit: Mon, 16 September 2013, 23:46:42 by kaotikb »
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
