Author Topic: Paint/Spray/Dip Keycap to change color?? Help?  (Read 2199 times)
Offline concept73
« on: Tue, 17 September 2013, 04:35:45 »
Has anyone considered spraying/painting keycaps?
Im finding it a little dificult to find Topre caps other than the limited sets at EK, so what im thinking about buying a set then maybe spraying/coating so then i can have the colors and design i'd like,
Any help/advice on this would be appreciated!
Poker 2 with reds
Soon to be a JD40 with reds
Re: Paint/Spray/Dip Keycap to change color?? Help?
« Reply #1 on: Tue, 17 September 2013, 07:21:55 »
If the key caps are ABS, you are pretty well out of luck. Some people paint them, but I am skeptical.
If they are PBT, however, you can do a lot.
Read post #14 of this thread:
http://geekhack.org/index.php?topic=35444.msg658453#msg658453
- D Trump 2026-10-24
Offline concept73
« Reply #2 on: Tue, 17 September 2013, 07:49:19 »
Ahh okay, thanks for the reply, i have minor OCD and MAJOR OCD when it comes to my keyboard and detailing, so it would have to be the best for me to be happy, but yeah ill look into it.
http://elitekeyboards.com/products.php?sub=access,toprekeys&pid=pdkb400ktbn
Poker 2 with reds
