Author Topic: Post your HHKB  (Read 4869 times)
Offline concept73
Post your HHKB
« on: Tue, 17 September 2013, 08:13:49 »
Been looking around and there is not a "Post your HHKB" and since i have one in the post I want to get some ideas ;)
I will post when mine arrives!
POST THEM HHKB'S!
Poker 2 with reds
Soon to be a JD40 with reds
Offline esoomenona
  • Gnillort?
Re: Post your HHKB
« Reply #1 on: Tue, 17 September 2013, 08:14:22 »
There is a Post Your Topre Keyboard thread: http://geekhack.org/index.php?topic=40658.0
Offline concept73
Re: Post your HHKB
« Reply #2 on: Tue, 17 September 2013, 08:17:07 »
Good enough for me ;)
Thanks for showing me this,
Moderator please remove :)
Poker 2 with reds
Offline esoomenona
  • Gnillort?
Re: Post your HHKB
« Reply #3 on: Tue, 17 September 2013, 08:20:05 »
You can lock it. Down at the bottom, on the left hand side, is a button to do just that.
