Author Topic: SP universal space-bar not fitting correctly on Ducky G2 Pro  (Read 2069 times)
Offline oaklandishh
« on: Tue, 17 September 2013, 12:20:31 »
So I have a Ducky G2 Pro and a QFR.  I recently got a SP grab bag with some space-bars and the Miami set which came with two. The universal space-bars fit fine on my QFR but when I put them on my Ducky it feels like there is some interference. The space-bar does not bottom out in the way the original one did or the extra one I got from WASD does. It makes me double hit space all the time probably meaning its coming up slowly too. Before I cut any stems off my universals I was wondering if anyone else had this problem and if there was a fix for it I could do. Thanks for your time.
This is as far as the universal will go down.
The green and black work perfectly, the white and the teal are sticky and the red does not work at all.
Offline MJ45
  • HHKB Pro
Re: SP universal space-bar not fitting correctly on Ducky G2 Pro
« Reply #1 on: Tue, 17 September 2013, 13:33:30 »
Most likely the distance between the outside stabilizer mounts is off compared to the Ducky spacebar, they look a little narrower to me. The QFR uses costar stabilizers which are more tolerable to dimensional variances than the Ducky cherry stabilizers.
