Author Topic: CM QF stealth (brown) - $49.99 after $20 mir Shell shocker (Ended)  (Read 2578 times)
Offline Badwrench
  • ummmm.....I forgot
« on: Thu, 19 September 2013, 02:57:34 »
Cooler Master CM Storm QuickFire Stealth SGK-4000-GKCM2-US USB or PS/2 Wired Compact Keyboard - CHERRY Brown
This is a Shell Shocker deal and starts at 3pm PDT
http://www.newegg.com/Special/ShellShocker.aspx?nm_mc=EMC-SD092013&cm_mmc=EMC-SD092013-_-SD091913-_-item-_-19-113-282&
« Last Edit: Mon, 23 September 2013, 00:15:33 by Badwrench »
Offline missalaire
  • Great Finder of Great Finds
Re: CM QF stealth (brown) - $49.99 after $20 mir Shell shocker
« Reply #1 on: Thu, 19 September 2013, 03:11:34 »
Nice find ;)
Offline phx
« Reply #2 on: Thu, 19 September 2013, 10:38:38 »
do I need another QFR?
probably not, but it's only $50....
edit: woah a lot of negative review on there... so many people got defective boards that didn't last very long.
« Last Edit: Thu, 19 September 2013, 10:40:20 by phx »
Offline nullstring
« Reply #3 on: Thu, 19 September 2013, 10:59:07 »
anyone heard about this? Was there an initial bad batch?
You'd think the PCBs would be exactly the same as the normal QFR..
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #4 on: Thu, 19 September 2013, 11:32:18 »
I am trying to teach my 11YO to touch-type, but blank keycaps were too much for him.  This might be a good compromise, and he already has a QFR.
Still, a set of front-print keycaps might be cheaper...
Hmmm.  Thanks for the find!
 - Ron | samwisekoi
Offline histevenhere
  • Student
« Reply #5 on: Thu, 19 September 2013, 11:51:06 »
What's wrong with the quality on these...The reviews are pretty bad for a QFR.
HHKB PRO 2, DAS ULTIMATE, SIIG MINITOUCH, KBT PURE, IBM MODEL M, MICROSOFT COMFORT CURVE 2000, CHERRY G84-4100, TG3-TP, QUICKFIRE RAPID, REALFORCE 87u
Offline Badwrench
« Reply #6 on: Thu, 19 September 2013, 12:09:10 »
You have to take bad reviews on Newegg with a grain of salt.  Most reviews - especially for something like this are usually negative.  No one wants to take the time if everything is fine, but if something is wrong - time for a negative review.
Offline tobr1an
« Reply #7 on: Thu, 19 September 2013, 13:10:51 »
Do these fit rapid replacement case?
« Reply #8 on: Thu, 19 September 2013, 13:29:28 »
Cool.
Offline sovano
« Reply #9 on: Thu, 19 September 2013, 13:43:51 »
Awesome! Definitely buying this. Thanks for the share.
« Reply #10 on: Thu, 19 September 2013, 14:25:26 »
From CoolerMaster's website:
The CM Storm Quick Fire Stealth is a refined Quick Fire Rapid aimed at purists and the gaming elite.
It's basically a QFR with side printed caps.  It should work.  However this seems to have a nice logo-less topcover, don't know why you'd want to replace it right away.
Offline ZRock
« Reply #11 on: Sat, 21 September 2013, 17:01:31 »
Darn, missed this >.<  Wanted to try out some cheap browns~
