Author Topic: Buying a HHKB Pro 2 very soon...NEED OPINION!  (Read 10513 times)
Offline TimIsABat
  • MX Clears are life
    • Instagram
« on: Thu, 19 September 2013, 13:24:42 »
So I have ultimately decided to buy a HHKB Pro 2. Now I could get the lettered version for 225 shipped and it is white and lettered, or I could throw in more money at 273 shipped before tax in blank. Just want some opinions. I have blank caps on my FC660M which I do like. I am just wondering if it is worth throwing in that extra money.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline hcry4
  • HHKB Hoarder
Re: Buying a HHKB Pro 2 very soon...NEED OPINION!
« Reply #1 on: Thu, 19 September 2013, 13:29:51 »
Probably shouldn't pay more for blank caps. You might as well buy an extra set of blank keycaps for just a bit more.
Offline oscillik
    • music podcasts
« Reply #2 on: Thu, 19 September 2013, 13:31:43 »
I was considering getting some blank caps for mine, but for password entry I would be lost. Ultimately, I'm happy with mine :)
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline TimIsABat
    • Instagram
« Reply #3 on: Thu, 19 September 2013, 13:34:25 »
If only those blank caps were cheaper x.x The caps are 89.61 shipped from EK. Is there another source to get blank caps for cheaper.
« Reply #4 on: Thu, 19 September 2013, 17:16:54 »
Not really any other source for blank Topre keycaps to suit HHKB.
In fact not really any other source for ANY Topre keycaps to suit HHKB.
Accepting Topre into your life means you have to make sacrifices to acquire accessories - like food.
Except Clacks - CC's a good guy who makes Topre offerings :)
« Reply #5 on: Thu, 19 September 2013, 17:22:38 »
Saying you want topre anything for cheap is like saying you can turn lead into gold. You just can't.
« Reply #6 on: Thu, 19 September 2013, 17:47:38 »
Is this a reference to the gold-plated HHKB?
« Reply #7 on: Thu, 19 September 2013, 17:59:07 »
Whaaaaaaaaaaaaaaaaaaaaaaaaat? Link pls.
« Reply #9 on: Thu, 19 September 2013, 18:24:08 »
Oh wow.
525000 yen is $5200 ish. Dayum!
Offline zoolzoo
« Reply #10 on: Thu, 19 September 2013, 18:25:23 »
I think you should get lettered because its cheaper and you will be able to see the legends when you type.
Leopold FC660C, Topre 45g | CM QFR, MX Blue | Rosewill RK-9000v2, MX Red | Cherry Slimline G84-4100, ML | Ducky One2 Mini RGB, MX Red
« Reply #11 on: Thu, 19 September 2013, 18:30:12 »
If you are used to the FC660M layout, HHKB won't be that alien to you, except for the arrow keys.  With blanks you might make a few mistakes until the muscle memory sets in.
Or what some people do is get (blank) coloured keycaps for the arrow keys on HHKB.
Offline meiosis
  • Time
« Reply #12 on: Thu, 19 September 2013, 18:41:07 »
Oh wow.
I think my dad has that at our Japan house -.-
Keyboards:
Aripeko TKL
« Reply #13 on: Thu, 19 September 2013, 18:53:37 »
Oh wow.
Does he use it, or is it merely on display? :)
Offline eth0s
  • Peace & Love
« Reply #14 on: Thu, 19 September 2013, 19:24:01 »
Get the blanks.  If you have already adjusted to blanks from you FC660C, then spend the extra ~$80.  You will get more than $80 worth of enjoyment out of it.  I suspect you may end up selling the FC660C, you will love the HHKB Pro 2 with blanks that much.
« Reply #15 on: Thu, 19 September 2013, 19:28:28 »
Unless you miss the arrow keys too much.
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #16 on: Thu, 19 September 2013, 19:31:31 »
I dont know about that. I own both the 660C and HHKB Pro 2 now. Haven't sold either. Really don't plan on it either, they're both exceptional keyboards.
Having a bad day?
« Reply #17 on: Thu, 19 September 2013, 19:31:45 »
Like this: http://geekhack.org/index.php?topic=40658.msg1048271#msg1048271
Offline TimIsABat
    • Instagram
« Reply #18 on: Fri, 20 September 2013, 18:46:51 »
I won't be looking at the legends since I so type with Colemak. Although the backspace and control key being at different locations may throw me off a bit. The price is better...
This is what I was debating. I really love the look of blank and I was going to get a blank red esc cap from EK as well...
Offline muad
« Reply #19 on: Fri, 20 September 2013, 18:56:00 »
Buy the lettered hhkb for 225, decide if you like it. If you like it then buy the blanks and sell the lettered caps?
Offline TimIsABat
    • Instagram
« Reply #20 on: Fri, 20 September 2013, 22:52:47 »
This is not a bad idea. I might just do this considering the layout is different even to my Poker X.
Offline muad
« Reply #21 on: Sat, 21 September 2013, 02:30:32 »
How do you like the layout on the poker x? Are you comfortable on it?
Offline TimIsABat
    • Instagram
« Reply #22 on: Sat, 21 September 2013, 10:12:09 »
I love it. I actually type faster with my Poker X than my FC660M. That also might be because of the ergoclears. I had no problems adjusting to using the Fn key or Fn+Spacebar for the arrow keys. I actually think the arrown diamond on the HHKB would be much more convenient.
Offline muad
« Reply #23 on: Sat, 21 September 2013, 10:51:45 »
Sounds like the HHKB work well for you. I say just go for it. After finishing my first week with the fc660c I really like topre. It's very different than cherry mx but I wouldn't say better. I still like the feel of ny mx browns (scratchiness is not there when typing normally) fc660m. There is certain charm to using the higher activation force topre because of its feel but typing on a low activation force cherry has a charm of it's own. If I could work with the HHKB layout I would have that instead of the fc660c, but only because it's soooo sexy!
Offline TimIsABat
    • Instagram
« Reply #24 on: Sat, 21 September 2013, 11:26:49 »
Which is why I am getting the HHKB Pro 2! I am getting it lettered for now because I am able to get it for cheaper than retail, although I do love the look of the keyboard with blank keycaps.
Offline Hypersphere
« Reply #25 on: Sat, 21 September 2013, 11:42:49 »
I just got mine yesterday, and I opted for the black on dark charcoal gray version. This gives me some options.
1. As it is in low light it looks like a blank black version.
2. When I forget the identify of a key, I can turn up the ambient lights and sneak a peek.
3. I can get complete sets of keycaps specifically for the HHKB Pro 2 in blank white or black or lettered white and light gray.
Although I like the Otaku look of blanks, I tend to prefer highly visible legends, and so I intend to replace the black on dark gray with a set of lettered white and light gray. This gives me the opportunity to showcase one of the great features of this keyboard, which is the beautiful dye-sublimated PBT keycaps -- arguably the nicest keycaps available for any keyboard, including the white/gray RF 87u and the IBM Model M or SSK.
Offline TimIsABat
    • Instagram
« Reply #26 on: Sat, 21 September 2013, 11:49:57 »
I have too many black on black boards so I decided to go for the white. If I can somehow get those blanks for cheaper it would be great.
Offline Hypersphere
« Reply #27 on: Sat, 21 September 2013, 11:59:44 »
With the white case, you still have many of the same options. You could go with blank white or black keycaps or lettered white or black keycaps. All the keycap sets are in stock on EK, and at $78 per set, this is a good price for high-quality dye-sub PBT keycaps.
Offline badcop
  • thorpe thocking master race
« Reply #28 on: Sat, 21 September 2013, 12:11:16 »
You can go with lettered now while you learn the function layer, sell the caps and buy blanks.
Offline TimIsABat
    • Instagram
« Reply #29 on: Sat, 21 September 2013, 20:17:20 »
I actually already have an offer for lettered caps so we'll see!
Offline Moosecraft
  • HHKB Pro
« Reply #30 on: Sun, 22 September 2013, 04:13:51 »
Let me know how you like the HHKB, I'm in the market for one now aswell and would love to hear your impressions :)
Offline terran5992
  • One With The Cup Rubber
« Reply #31 on: Sun, 22 September 2013, 07:24:39 »
Buy it, If you dont like it sell it to me :)
Offline TimIsABat
    • Instagram
« Reply #32 on: Sun, 22 September 2013, 18:10:27 »
I will write up a review after a few weeks of having it.
« Reply #33 on: Sun, 22 September 2013, 18:18:30 »
Everyone getting HHKBs now... I want to get one and be a cool kid :D
Offline Xenderwind
« Reply #34 on: Sun, 22 September 2013, 18:20:40 »
I'm on the verge of getting one but haven't pulled the trigger yet.  Worried I wont like my GON anymore :(.
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline Michael
  • Formerly Bro Caps
« Reply #35 on: Sun, 22 September 2013, 18:24:50 »
I dunno why... they're just overpriced rubber domes.... gosh....
« Reply #36 on: Sun, 22 September 2013, 18:26:46 »
Ye that's why I'm not getting one ;)
« Reply #37 on: Sun, 22 September 2013, 18:59:44 »
Yes, but what wonderful domes they have.
« Reply #38 on: Sun, 22 September 2013, 19:15:26 »
They aren't cool anymore since I have one.
Offline eth0s
  • Peace & Love
« Reply #39 on: Sun, 22 September 2013, 19:17:14 »
umm, you're already the coolest kid here.  But an HHKB will get you into demik's HHKB kLub, which is also pretty kewl.
« Reply #40 on: Sun, 22 September 2013, 19:18:42 »
Just to be sure I got a realforce and type heaven for good measure.
« Reply #41 on: Sun, 22 September 2013, 19:38:22 »
Thorpe dedicated!
« Reply #42 on: Sun, 22 September 2013, 19:50:13 »
Thorpe dedicated!
Not yet haha.
« Reply #43 on: Sun, 22 September 2013, 19:54:01 »
Thorpe dedicated!
Not yet haha.
You have three Thorpe, I have but one.
« Reply #44 on: Sun, 22 September 2013, 20:23:08 »
Just two now I'm sending the type heaven to my mother for her birthday. I told her if she hated it to let me know and I'll sell it here and buy her something else.
Thorpe dedicated!
Not yet haha.
« Reply #45 on: Sun, 22 September 2013, 20:46:55 »
Thorpe dedicated!
Not yet haha.
Was that a content-free post?
Offline Xenderwind
« Reply #46 on: Sun, 22 September 2013, 20:47:38 »
Thorpe dedicated!
Not yet haha.
is what he meant to say
« Reply #47 on: Sun, 22 September 2013, 20:55:29 »
Thorpe dedicated!
Not yet haha.
Somehow I typed it in between quotes haha
« Reply #48 on: Sun, 22 September 2013, 21:06:37 »
Thorpe dedicated!
Not yet haha.
Lucky mother!
Offline PadawanGeek
« Reply #49 on: Sun, 22 September 2013, 21:10:14 »
I so want a 55G 87U, or an FC660C, just waiting for the local distributer to bring stock of them in.....then it'd down to which comes first.
