Author Topic: can anyone tell me something about this keyboard?  (Read 3144 times)
Offline foxtrott
« on: Fri, 20 September 2013, 14:38:54 »
Hey Guys,
anyone knows this keyboard?
I found it at recycling center  ;D
beautiful old doubleshots.. und very heavy.  :)
Offline divito
Re: can anyone tell me something about this keyboard?
« Reply #1 on: Fri, 20 September 2013, 14:43:07 »
That seems like a great find. Can't wait to hear more about it.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline Tarzan
  • formerly known as Greystoke
« Reply #2 on: Fri, 20 September 2013, 14:51:26 »
They look like they could be Cherry M7 switches, perhaps the later variant referred to on the DT Wiki that had retaining clips on the sides.
http://deskthority.net/wiki/Cherry_M9
Nice keyboard, those are beautiful keycaps!
Edit: Updated to reflect Cherry M9, not M7.   :D
« Last Edit: Sat, 21 September 2013, 20:34:37 by Greystoke »
Offline foxtrott
« Reply #3 on: Fri, 20 September 2013, 14:58:03 »
how can you just throw something in the garbage?
I clean the caps now...  very thick doubleshots
http://geekhack.org/index.php?topic=41117.0#post_Cherry
Cherry M7... older than the MX !!  :eek:
« Last Edit: Fri, 20 September 2013, 15:05:37 by foxtrott »
Offline Parak
« Reply #4 on: Fri, 20 September 2013, 15:08:28 »
Hey, that looks familiar :P
http://imgur.com/a/JGEOB
Offline Tarzan
« Reply #5 on: Fri, 20 September 2013, 15:14:27 »
Actually, using the Adler typewriter as a search term, your find looks like it may use Cherry M9 switches.
Additionally, the shell design of the MX switch is borrowed from the M9, including the shell retention clips and the four holes in the top used for releasing them.
Little else is presently known about the M9 switch, as it appears to be by far the least widely used of the three types. However, by 1984, with the introduction of the Cherry MX, this form factor became dominant with the immediate and rapid adoption of the new switch.
Sounds like a pretty rare find!
Offline tricheboars
  • Keyboards are Important!
« Reply #6 on: Fri, 20 September 2013, 15:55:38 »
whoa. those caps are freaking awesome and that board is really cool. please use that monster. what connection cable port does it utilize? AT? XT? PS/2 (fantasy hope)?
those caps. man they are awesome. and is that a 8x spacebar?!?
Offline Daniel Beardsmore
  • RIP
    • Boring twaddle
« Reply #7 on: Fri, 20 September 2013, 16:38:43 »
Cherry M9. It was their "low-profile" switch — same size as the successor the MX, but most of the switch is under the plate. It does look like a reduced size M7, but it introduced changes to the shell that were re-used in the MX (removable lid with side retention clips and holes in the top to release it).
I should be getting one or two some time this year that I can disassemble for the DT wiki, but feel free to beat me to it (you could even enter the photos into the wiki photo competition).
No idea what the keyboard is, though.
Bore Awards
Offline Parak
« Reply #8 on: Fri, 20 September 2013, 16:51:37 »
You can use the pics I took (and posted to DT) a while back, if you prefer, though they kinda suck..: http://imgur.com/a/1zBTQ
The switch stem is also quite different and longer.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #9 on: Fri, 20 September 2013, 16:51:49 »
Appears to be something from TA, there are several typewriters that have the same look, keycaps. M9 switches are pretty common in TA typewriters made in the early 80's before they switched to MX and then quickly to MY or worse for cost savings.
My guess is that it goes to some model of professional grade electronic word processor.
  • RIP
    • Boring twaddle
« Reply #10 on: Fri, 20 September 2013, 16:53:31 »
I guess I saw those before — I was sure I'd seen something that demonstrated that the M9 was the same inside as the M8.
Bore Awards
Offline foxtrott
« Reply #11 on: Sat, 21 September 2013, 02:36:51 »
There are probably the same buttons like this:
http://geekhack.org/index.php?topic=47636.msg1018535#msg1018535
on the connection cable is TA..  so triumph adler
but I have no idea whether you can convert the plug to ps2
the caps are certainly fantastically beautiful .. I will post pictures  ;) :D :D :thumb:
  • RIP
    • Boring twaddle
« Reply #12 on: Sat, 21 September 2013, 06:37:37 »
Interesting — looks like Cherry M9 was popular for typewriters!
Bore Awards
