Author Topic: Key 'wobble'  (Read 10706 times)
Offline slashbreak
Key 'wobble'
« on: Fri, 20 September 2013, 21:50:58 »
Wondering whether there's a more searchable term for the nasty sound the keys make when your fingers are resting on them or sliding over them? Rattle? Wobble? The couple of cheap membranes I have all make a lot of noise, but I'm hoping a well-made one won't.
Could you tell me if your board is quiet when your fingers are on it, and the model of said board?
Cheers
« Last Edit: Fri, 20 September 2013, 22:01:08 by slashbreak »
Re: Key 'wobble'
« Reply #1 on: Fri, 20 September 2013, 21:56:51 »
my... my boards don't make any sounds while my fingers rest on them.
Offline terran5992
  • One With The Cup Rubber
Re: Key 'wobble'
« Reply #2 on: Fri, 20 September 2013, 22:06:04 »
No wobble on topre
Re: Key 'wobble'
« Reply #3 on: Sat, 21 September 2013, 01:20:42 »
My keys wobble slightly, that is normal because there is a little play around the stem to allow the keycap to move up and down freely.
Doesn't make a noise though, apart from a very quiet plastic tick sound like unto two pieces of plastic hitting from a small distance apart, which is exactly what is happening.
Offline Moosecraft
  • HHKB Pro
Re: Key 'wobble'
« Reply #4 on: Sat, 21 September 2013, 06:57:29 »
I have not experienced this with a mechanical keyboard, not even close really.
Offline Grim Fandango
Re: Key 'wobble'
« Reply #5 on: Sat, 21 September 2013, 07:08:51 »
No wobble here. But I think it has more to do with the keycaps (few people here use the stock keycaps their keyboard came with) than is has to do with the exact model of the keyboard. None of the keycap sets I have tried have this wobble. I am currently using a set of Vortex PBT keycaps and there is very little to no wobble as they are quite a tight fit. I ahve only really experienced it with bad fitting custom keycaps.
Offline slashbreak
Re: Key 'wobble'
« Reply #6 on: Sat, 21 September 2013, 07:11:43 »
well that's good to know; I expect it's just my cheap boards. Anyway, I just ordered a QFR stealth blue, so I'll find out soon (but not soon enough)
Offline terran5992
Re: Key 'wobble'
« Reply #7 on: Sat, 21 September 2013, 08:06:12 »
Id doubt that they will wobble. Coolermaster is quite a reliable brand .
And QFR is an extremely reliable board
Re: Key 'wobble'
« Reply #8 on: Sat, 21 September 2013, 10:27:38 »
My Cherry MX Clear keyboards rattle a little if the fingers slide across the keys. I think that some of that noise comes because there is a bit of play between slider and housing and some of it is because the switch is under tension and when you slide the fingers across you actually press the keys oh so slightly.
The one with plate-mounted switches and thick PBT keycaps have a higher pitch than the one with PCB-mounted switches and thick POM keycaps.
The keyboards don't rattle (enough for me to hear it) when I lift and shake them, but some of my rubber domes do, as does a Cherry MY keyboard I have.
« Last Edit: Sat, 21 September 2013, 10:29:50 by Findecanor »
Offline 1391406
Re: Key 'wobble'
« Reply #9 on: Sat, 21 September 2013, 14:37:51 »
The white Alps board I have (NTC brand) has some play and wobble, but I've heard Alps are notorious for that.
Re: Key 'wobble'
« Reply #10 on: Sat, 21 September 2013, 14:41:39 »
my DK1087 does the same.
Offline fatmav
Re: Key 'wobble'
« Reply #11 on: Sat, 21 September 2013, 17:52:33 »
My Matias Laptop Pro wobbles quite a bit more than I would like it to. But ALPS (or ALPS-inspired) switches seem to have a reputation of having this problem...
Offline Phedran
    • Phedran.com
Re: Key 'wobble'
« Reply #12 on: Sat, 21 September 2013, 18:27:09 »
I'm trying my first mechanical keyboard and the sounds from running fingers over the keys seems quieter on this board than my old membrane. My guess is that based on the way Topre switches work that they might be even more quiet in general but I don't know for sure. Switch stickers might limit a little bit of movement on Cherry MX boards. I think all keyboards have a little bit of play, it's more about finding one that you like the sound and feeling of (maybe even the wiggles).
Offline kaotikb
Re: Key 'wobble'
« Reply #13 on: Sat, 21 September 2013, 22:14:09 »
Do you mean the sound like the following video?
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Offline slashbreak
Re: Key 'wobble'
« Reply #14 on: Sun, 22 September 2013, 07:25:06 »
Yep, that's it. Absolutely disgusting! Does your QFR do it too?
Offline Altis
Re: Key 'wobble'
« Reply #15 on: Sun, 22 September 2013, 09:10:22 »
My few year old DAS silent does it quite loudly (MX Brown).  I've been wanting to find a mechanical keyboard that doesn't do it... hoping the Ducky Shine 3 TKL will be the one.
Offline fatmav
Re: Key 'wobble'
« Reply #16 on: Sun, 22 September 2013, 09:13:58 »
Is there some kind of gel or grease that can be put between the switch axle and keycap to dampen this effect?
Offline terran5992
Re: Key 'wobble'
« Reply #17 on: Sun, 22 September 2013, 09:21:27 »
My unicomp model m wobbles alot. But that is just the nature of buckling spring keyboards
Offline czarek
  • Keep the momentum going!
    • FalbaTech
Re: Key 'wobble'
« Reply #18 on: Sun, 22 September 2013, 11:51:39 »
No wobble on topre
Yea right... especially on a left Control / Caps Lock key :)
Offline fatmav
Re: Key 'wobble'
« Reply #19 on: Sun, 22 September 2013, 11:58:15 »
I would not go so far to say that there is no wobble on Topre (at least that is not the case on my 55g), but I would say that the wobbling on a Topre does not make any noise in the following test: (1) rest a finger on a key and (2) try to move the finger around in a circle while touching the key surface very slightly.
This matters to me since (as we learn from Topre "Silent") that the up-stroke is responsible for quite a bit of noise too. From my experience of typing on the Matias Laptop Pro, the majority of the noise actually comes from the up-stroke and the key vibration due to the wobbling.
Offline Loligagger
Re: Key 'wobble'
« Reply #20 on: Sun, 22 September 2013, 12:05:46 »
I always found MX boards had less play with the keycaps than a regular rubber dome. There are always switch stickers if you want to cut down on that wobble further. It won't eliminate key wobble completely, only the slight play between the two halves of the mx housing.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: Key 'wobble'
« Reply #21 on: Sun, 22 September 2013, 12:13:02 »
there is definitely wobble on the topre lower stem. you can't injection mold to no-wobble tolerances. from the factory they try to clamp down on this by applying silicone grease, but over time the silicone moves around quite a bit and the board loosens up. the new type heaven switches are actually non-lubricated (because that costs money!). what's interesting about topre stems is that the wobble isn't just mechanical but pneumatic. what i mean by that is that the stem inner and outer actually form a vacuum seal under which the rubber cup operates.
long story short, my solution for this (untested on an entire board so far, but tested by playing around with some keychains) is krytox 206. a find bead around the edges of the stem inner seals the keyswitch and makes a HUGE difference to the feel. i would actually guess that it adds like 5g of actuation force, at least. and that was on a type heaven keychain. the tooling for the proper realforces seems to be more precise than the type heaven.
Offline kaotikb
Re: Key 'wobble'
« Reply #22 on: Sun, 22 September 2013, 17:22:58 »
Yeah does the same. But not as bad as that. The video also exaggerates it a little.
I have had rubber dome boards that do the same.. Like the old compaq i have from 2000 or so is pretty bad.
