Author Topic: SSK Numlock?  (Read 2230 times)
Offline cgbuen
    • cgbuen.io
SSK Numlock?
« on: Sat, 21 September 2013, 14:32:56 »
I just got one in recently.. How do you access all the layers (letters, numbers, and navigation) on an SSK? Here's what I've figured out so far:
Toggling shift + numlock toggles between the letters and then either the numbers or the navigation keys. If I'm in the non-letter mode and I hit numlock on another keyboard plugged in, then it toggles between numbers navigation. Shift + numlock on my SSK again will take me back to letters.
But how do I access all three layers from just the SSK alone?
« Last Edit: Sat, 21 September 2013, 14:34:29 by cgbuen »
Offline cgbuen
    • cgbuen.io
Re: SSK Numlock?
« Reply #1 on: Mon, 14 October 2013, 17:58:16 »
Bump.
Offline JimByr
  • ...old guy...
Re: SSK Numlock?
« Reply #2 on: Mon, 14 October 2013, 18:16:52 »
The third layer is using [Shift] when in the active Numlock state. That gives you the front-printed keys such as Home, End, PgUp, PgDn, Ins, Del, and the arrows.
