Author Topic: Which Model M?  (Read 6341 times)
Offline Belfong
Which Model M?
« on: Mon, 23 September 2013, 05:25:33 »
So, I have also been on a quest to try the ultimate in mechanical keyboard and send words out in the streets and a couple came back with these model M (are they even Model M?, Deskthority wiki think so):
Partno 82G2383 (clearly labelled Model M behind) - date is 16 Mar 94
Partno 42H1292 - date is 25-2-97
Partno 1394540 (also clearly labelled Model M) - date is 6 Mar 92
Which should I consider. All of them are missing one or two key caps. They are dirty, the 1394540 being the 'cleanest'. I am not sure how functional are these. All have PS/2 except 1394540 which has a PS/2 like thingy but is attached to the keyboard via a detachable cable. The detachable cable doesn't look like you can find them anywhere.
Re: Which Model M?
« Reply #1 on: Mon, 23 September 2013, 06:07:40 »
I'll let someone more knowledgable advise which one to get, but will note that the detachable cable is an SDL cable, and you can get SDL to USB cable here: http://www.ebay.com.au/itm/270955553909?ru=http%3A%2F%2Fwww.ebay.com.au%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D270955553909%26_rdc%3D1
That cable is highly recommended by quite a few people around here, including me who uses one to connect a Model M to a Mac.
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
Re: Which Model M?
« Reply #2 on: Mon, 23 September 2013, 06:30:25 »
do the leds on your model m work with that cable connected to your mac? I use the bluecube adapter in combination with the original sdl cable and the leds dont work when connected to my mac. they only light up once when I connect it.
Offline Belfong
Re: Which Model M?
« Reply #3 on: Mon, 23 September 2013, 06:32:27 »
Will such old keyboard work via USB? That would be great then but I suppose no NKRO.
Re: Which Model M?
« Reply #4 on: Mon, 23 September 2013, 06:50:55 »
Orihalcon's USB cables work well but the Model M has only 2KRO.
I would recommend a 139xxxx over the later models, but I like the older ones in general.
If you do not mind taking them apart, they are easy to clean and rehabilitate.
- D Trump 2026-10-24
Re: Which Model M?
« Reply #5 on: Mon, 23 September 2013, 06:57:47 »
You can buy only one of them? ... Otherwise mix and match keycaps to get a full set, choose the assembly with the most plastic rivets intact and the controller with detachable cable.
Offline Belfong
Re: Which Model M?
« Reply #6 on: Mon, 23 September 2013, 07:31:51 »
Yeah I can only buy one. Because of the costs and because I won't know what to do with so many, otherwise. Resell them? Ha ha.
Offline 1391406
Re: Which Model M?
« Reply #7 on: Mon, 23 September 2013, 07:54:34 »
I'd go for the 1394540. It's the earliest M listed and, unlike almost every other Model M, has an integrated speaker.
Re: Which Model M?
« Reply #8 on: Mon, 23 September 2013, 08:03:34 »
At some point you realize that it is worth having a parts donor. Unicomp and clickykeyboards sell sets of keycaps for $30. At that price point, it often makes sense to buy a whole keyboard to harvest caps and other parts from.
Offline TimIsABat
  • MX Clears are life
    • Instagram
Re: Which Model M?
« Reply #9 on: Mon, 23 September 2013, 08:13:31 »
Crystals yo
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline Belfong
Re: Which Model M?
« Reply #10 on: Mon, 23 September 2013, 09:01:24 »
That's a good point foghast. Thing is, if I were to buy all 3 I might as well clean, then resell them to buy the newer key cap set from Unicomp. But the base cost is quite high for me to afford all 3.
How rare are these?
And cleaning them should be easy right. Do I have to unplug both layers of the keys? There are two layers for every key, which was a good way to change key cap, I suppose.
Re: Which Model M?
« Reply #11 on: Mon, 23 September 2013, 09:16:10 »
Keys are easily removed, separated, and cleaned.
You may not be able to get the same $30 that the established stores charge, and many people consider the old IBM caps to be superior to Unicomp's.
Unicomp has a dazzling array of color choices, etc, but if you want more than a small handful of "accent" keys they get very pricey in a hurry.
clickykeyboards sells old reclaimed stock.
Buying 3 keyboards might be a good way to get 2 that you really like, perhaps one to mod and decorate, and one to keep stock.
Sell off the 3rd at a low price, perhaps missing caps, to recoup some of your costs.
Offline 1391406
Re: Which Model M?
« Reply #12 on: Mon, 23 September 2013, 12:08:12 »
What are they asking for all three?
Offline 1391406
Re: Which Model M?
« Reply #13 on: Mon, 23 September 2013, 12:10:53 »
Re: Which Model M?
« Reply #14 on: Mon, 23 September 2013, 17:13:25 »
Caps Lock LED - definitely.
Num Lock - nope, as the Mac does not have num lock functionality.
Scroll Lock - can't remember, but probably not - no equivalent Mac functionality.
All LEDs work when the keyboard is connected to a Windows-based PC.
Offline Belfong
Re: Which Model M?
« Reply #15 on: Mon, 23 September 2013, 19:26:27 »
It's from two different sellers. They are asking around $70-$80. Is that a fair price?
Since I have to do some cleaning, any special chemical I should use or just warm water and soap?
« Last Edit: Mon, 23 September 2013, 20:36:39 by fohat.digs »
Offline vivalarevolución
Re: Which Model M?
« Reply #17 on: Mon, 23 September 2013, 20:43:23 »
All of the above.  Except the rubber domes that look like Model M's
Offline 1391406
Re: Which Model M?
« Reply #18 on: Mon, 23 September 2013, 20:57:08 »
You can use water, but some stains aren't water soluble(eg. ink). Some people recommend detergent, however I prefer alcohol, although I wouldn't use it on labels that aren't laminated. After I open the case, I use compressed air to blow out any debris.
Offline Belfong
Re: Which Model M?
« Reply #19 on: Mon, 23 September 2013, 21:40:39 »
$70-80 for 3 is a good price. For 1 it is not. You could get a new Unicomp for that.
It looks to me like the going price on ebay for a good used 1391401 is $40-50 + shipping.
What do you mean for 1 it is not - do you mean that the 13xxx is not worth $70?
Thanks for the ebay links!! I can use that to negotiate; much much appreciated!
Edit: I get it .. you mean $80 for all 3 keyboards.
Unfortunately no; the sellers are asking $70 each. So I will use the ebay links to negotiate. Of course, I am in Malaysia, in which Model M is relatively rarer, so the seller has an edge!
« Last Edit: Mon, 23 September 2013, 22:45:43 by Belfong »
Offline ch_123
Re: Which Model M?
« Reply #20 on: Tue, 24 September 2013, 03:40:50 »
I'd go for the '4540 because it's unique (they're not exactly rare, but they're less common than the run of the mill Ms)
Re: Which Model M?
« Reply #21 on: Tue, 24 September 2013, 09:24:53 »
I agree, and the older model lexmark keyboards are really quite good. I have a beige label lexmark 1391401 from 6-11-92 (lexmark branding only exists on the controller) and I find it of acceptable quality when compared with my much older 1390120.
That said, $70 is maybe a little high for a model M. You can get them commonly for much less in the USA, though internationally they are less common, and often $70 is a good price.
Offline Belfong
Re: Which Model M?
« Reply #22 on: Wed, 25 September 2013, 06:38:40 »
I'm embarrassed to admit that I bought the Code when it was available yesterday just because I have a feeling I will like Clear and because it's so hard to grab one; yesterday was like a chance in a lifetime. As such I have way, way overspent and will not be able to afford these Model M, which now seemed so easy to obtain. Alas!!
Offline snoopy
  • The Flying Ace
Re: Which Model M?
« Reply #23 on: Wed, 25 September 2013, 08:43:05 »
decided to buy a crappy mx board instead of a Model M? - bad decision... But you're new... so its ok to learn it the "normal" way... ;)
Offline Belfong
Re: Which Model M?
« Reply #24 on: Wed, 25 September 2013, 09:13:31 »
LOL.. I may be new to GH and new to collecting keyboard but I am not new to mech keyboard. Have used the Model M for 5 years, 20 year ago in my first job. But I know how noisy and clumsy it will be in my quiet PC room.
Offline rowie
Re: Which Model M?
« Reply #25 on: Wed, 25 September 2013, 13:39:56 »
Interesting to hear that they are "clumsy" to you since I feel it would be my fingers that would be clumsy instead of the keys. I do however regret getting a model m2 keyboard because they are known to have capacitor problems, and yes it is true I had to replace the capacitors two times so I moved on to a silver label model m which is expected to arrive today.  :thumb:
Offline rowie
Re: Which Model M?
« Reply #26 on: Wed, 25 September 2013, 13:42:50 »
I am also tempted to get a clear switch, but I think what is first on my wishlist is a Ducky Shine 3 in either blue or green switch.  ;D
Offline Belfong
Re: Which Model M?
« Reply #27 on: Wed, 25 September 2013, 19:31:16 »
By clumsy I meant the size of the whole keyboard, not the keys. I love them. Just that in this modern era of tight and clean workspace, having a model M would be so out of place.
Offline rowie
Re: Which Model M?
« Reply #28 on: Thu, 26 September 2013, 18:35:52 »
I suppose aesthetically it will vary on an individual case. Here I was poking fun at the Ducky Mini and now i'm considering getting one just so that I can have that ultra "modern" look and ultimate in spacesaver. However, when I am at home in my own office I go back to my reliable model M keyboard. Can I say I retired my model M2 keyboard and I now love typing on the silver label. It's like typing on a bouncy gymnastic spring floor. Still, i'll probably rotate using keyboards knowing me since I don't think I can just settle using just one type thanks to this forum. ;D
