Author Topic: Hullo! (a brief greeting and one question)  (Read 2982 times)
Offline shmibs
  • ohithur
« on: Mon, 23 September 2013, 10:49:59 »
so i stumbled across this site a couple of months ago, and you people have got me hooked X_X
this HHKB is the best thing that has ever happened to my programming work flow. it's not all that good for games, though, so i think i'm ready to start looking around for a second board. does anyone have any suggestions for compact cherry red boards that have lots of potential for custom cap purtiness? should i be looking for a different type of switch instead?
HHKB2 PD-KB400W
Offline Linkbane
Re: Hullo! (a brief greeting and one question)
« Reply #1 on: Tue, 24 September 2013, 00:27:09 »
Well, for gaming, assuming that you don't use the numpad or would prefer the mouse being closer for the numpad, I would suggest the Quickfire Rapid, which simply has the numpad removed, or any of its TKL brothers. Leopold is a well-known and nice board, according to what I've seen of pictures from them.
For gaming, generally the preferred switches are MX Red or Black, based on the pressure that you like from the keys. Browns work quite well, and Blues are usually more typing-reserved.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline skuko
« Reply #2 on: Tue, 24 September 2013, 05:15:38 »
get a TKL filco with reds and don't look back :)
also, welcome to wallethack.
Offline Linkbane
« Reply #3 on: Tue, 24 September 2013, 08:25:44 »
You want his first keyboard and for gaming to be a Filco?
Come on, go easy on his wallet. It needs some lubrication before the dollars start flowing.
But of course, the Filco is a great keyboard and if you want to get it, it's a great choice.
Offline SnareSpectre
« Reply #4 on: Tue, 24 September 2013, 11:22:31 »
I can't recommend the Quickfire Rapid enough. It is SUCH a solid board, and at such an amazing price. Although I haven't tried an insane amount of boards, the QFR exceeded my expectations significantly, and I can't possibly imagine what a board that costs twice as much has to offer over it, with the exception of PBT keycaps.
Linkbane is correct about the "general perception" of the keyswitch types, but I disagree that specific switches are better for different utilities. My first keyboard choice had MX Blacks because I heard they were "great for gaming," but I was extremely disappointed. I returned it and went for a QFR with blues, and instantly felt right at home. I play both Starcraft 2 and Black Ops 2 and prefer blues for both, despite it not being a "gaming" switch per se.
Find a way to try out the switch types if at all possible (although most are not readily available) - in my opinion, switches are more suited to the user, not the utility.
Offline shmibs
  • ohithur
« Reply #5 on: Tue, 24 September 2013, 14:30:08 »
the self-advertising on the quickfire is so loud and those filcos look so nice, though... :P
the only two things i really care about for this would be "quiet" and "easy to press" (no strain from extended keypresses), both of which it sounds like reds are good for.
so, filco tkl with red switches it is!
* shmibs moves to press a "place order" button, stops, checks a bank account balance first.
...next month  ;D
HHKB2 PD-KB400W
Offline Linkbane
« Reply #6 on: Tue, 24 September 2013, 16:10:53 »
...next month  ;D
I agree, some just really like using one type of switch for every application. I personally would think that MX Black switches are the absolute worst, and I know that many just love gaming on Blues. I meant that most like Reds, as I do, and that most like Blues for typing, but I still find Reds very comfortable and lovely to use (albeit inferior in accuracy and speed).
So, great choice in the Filco and have fun with your new keyboard, rich first poster!
