Author Topic: HHKB P2 delete key default  (Read 3889 times)
Offline jmchargue
« on: Mon, 23 September 2013, 14:30:40 »
What's up with the backspace key being delete, by default? Is there a memo that I missed explaining how this is more useful? I kind of don't want to change it, because I know there should be some reason for it being this way..
Offline longweight
  • philanthropist
Re: HHKB P2 delete key default
« Reply #1 on: Mon, 23 September 2013, 14:32:38 »
As standard it is backspace on my board....
Offline jmchargue
« Reply #2 on: Mon, 23 September 2013, 14:37:48 »
>dat upper right hand corner.
That is odd that yours is not like this.
Offline esoomenona
  • Gnillort?
« Reply #3 on: Mon, 23 September 2013, 14:43:11 »
Dipswitch allows you to quickly change that.
Offline badcop
  • thorpe thocking master race
« Reply #4 on: Mon, 23 September 2013, 14:43:14 »
dipswitch 3 changes it to a backspace and moves the delete to function+~ key
Offline longweight
  • philanthropist
« Reply #5 on: Mon, 23 September 2013, 14:45:30 »
I have top right hand key as BS and FN+DEL= DEL.
I have the blank version.
« Last Edit: Mon, 23 September 2013, 14:47:19 by longweight »
Offline jmchargue
« Reply #6 on: Mon, 23 September 2013, 14:53:22 »
Yeah, I've been messing with all the different configurations, I'm just wondering why it was made to be delete by default. How could this be an advantage? In terminal use maybe?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Mon, 23 September 2013, 15:27:30 »
hhkb is basically a reduced size Sun/Unix keyboard and was modeled after that.
Offline eth0s
  • Peace & Love
« Reply #8 on: Mon, 23 September 2013, 16:12:41 »
Japanese don't make mistakes, so they don't ever use the backspace.  Only clumsy Westerners have to go backwards.  Dipswitch option was added for fat-fingered Westerners.
Offline oscillik
    • music podcasts
« Reply #9 on: Mon, 23 September 2013, 16:30:22 »
As IvanIvanovich mentions:
Keymacs A620N-Rev.A with Alps SKCM Salmon switches
Offline ch_123
« Reply #10 on: Tue, 24 September 2013, 05:36:29 »
IIRC, Delete is used as Backspace in Emacs. Hardcore vi/vim users would probably use x instead of backspace too...
On the later Sun Type 5, they put Backspace where Delete is located on that Type 3, and moved Delete to where you'd find it on a modern PC keyboard.
« Last Edit: Tue, 24 September 2013, 05:41:03 by ch_123 »
Offline oscillik
    • music podcasts
« Reply #11 on: Tue, 24 September 2013, 05:42:04 »
okay, but the HHKB is based on the Type 3 keyboard, so the Type 5 is completely irrelevant.
Offline ch_123
« Reply #12 on: Tue, 24 September 2013, 05:43:27 »
I wasn't contradicting you, I was merely ruminating on the progression of Sun's layouts over time ;)
Offline oscillik
    • music podcasts
« Reply #13 on: Tue, 24 September 2013, 16:26:38 »
I should probably wake up before I post! Sorry, internet got a bit too serious there  :-[
