Author Topic: Cherry G80-3000LSCXX with blank keycaps  (Read 6965 times)
Offline Chloe
  • Switch Kitten
« on: Sat, 06 December 2008, 20:44:33 »
I really like the look of this keyboard in white. It would be nicer if the LEDs were blue:
http://translate.google.com/translate?hl=en&sl=cn&u=http://www.iqmore.idv.tw/archives/520
Offline wellington1869
« Reply #1 on: Sat, 06 December 2008, 21:23:03 »
all white is very elegant.
using: ms 7000/Das 3
Offline Chloe
  • Switch Kitten
« Reply #2 on: Sat, 06 December 2008, 21:37:57 »
I think I'd prefer a large keyboard to be all white like this, and a compact to be charcoal black like the HHKB. I really hope Cherry start making these keyboards available in Europe and the US.
Offline lowpoly
« Reply #3 on: Tue, 09 December 2008, 04:55:07 »
LOL, the Das II raised from the dead. White looks nice though.
Cherry has a creative marketing manager somewhere in the far east.
Offline Eclairz
« Reply #4 on: Tue, 09 December 2008, 08:03:27 »
it is available in europe but you'll have to find a german reseller to ship it to yo your preferred country and since it uses the european standard which the british/french/german/etc keyboards also use there won't be a problem if your used to european layout.
It will probably be about the same price if you can get your hands on them but additional delivery costs unless you live in germany
Lenovo ThinkPad TrackPoint Keyboard
RealForce 45g UK 88UB
FILCO Majestouch TenKeyPad
Offline lowpoly
« Reply #5 on: Tue, 09 December 2008, 09:09:46 »
Quote from: Eclairz;13983
Any links? Often xx in the model-no means that you have to replace it by the actual country code.
Offline Ulysses31
« Reply #6 on: Tue, 09 December 2008, 09:14:30 »
Why does the translation keep referring to squirrels?  This something to do with a comparison with KBtalking?
Offline lam47
« Reply #7 on: Tue, 09 December 2008, 09:45:51 »
It looks soooo nice in white.
Does it say green cherries?
Im going to be needing one of these for sure.
Christ Im addicted.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline lam47
« Reply #8 on: Tue, 09 December 2008, 09:47:13 »
just clicked a picture and got loads more! They are blues.
Offline Chloe
  • Switch Kitten
« Reply #9 on: Tue, 09 December 2008, 09:50:56 »
It's poor translation, they have blue Cherries. 青 can mean blue or green.
Offline D-EJ915
« Reply #10 on: Tue, 09 December 2008, 12:37:51 »
That looks great, replacing the LEDs would be easy too, just use a multimeter to figure out the voltage through the LED (if it doesn't say on the board) and then buy some new ones and solder them in.
Offline lam47
« Reply #11 on: Tue, 09 December 2008, 13:38:12 »
Quote from: D-EJ915;14015
Im thinking blue or violet :)
Offline Eclairz
« Reply #12 on: Tue, 09 December 2008, 14:49:20 »
green cherrys = black + blue clicky and heavy probably for the buckling spring owners with finger super muscles
Offline lam47
« Reply #13 on: Tue, 09 December 2008, 15:00:20 »
Has anyone found where to buy one yet?
Offline lowpoly
« Reply #14 on: Wed, 10 December 2008, 05:26:54 »
On current Cherry controllers you have SMD LEDs:
Offline zwmalone
« Reply #15 on: Wed, 10 December 2008, 19:24:12 »
Can you get one of these in a standard US layout?
If not, am I correct in assuming this has Blue Cherrys?
Can't get enough of them ALPS
Offline lowpoly
« Reply #16 on: Thu, 11 December 2008, 02:10:20 »
Quote from: zwmalone;14233
G80-3000LSCEU has blue Cherries. 'S' is the blue switch, 'EU' is the ANSI version (horizontal enter, lettered keycaps).
Offline Chloe
  • Switch Kitten
« Reply #17 on: Thu, 11 December 2008, 07:56:27 »
Quote from: lam47;14033
3500 TWD:
http://translate.google.com/translate?hl=en&sl=cn&u=http://www.talkdigi.net/kbt/cherrynoword.html
I don't know what the minimum purchase order is to have some made up.
Offline lowpoly
« Reply #18 on: Thu, 11 December 2008, 08:08:13 »
Quote from: Chloe;14258
3500 yuan is a bit much:
That board has linear switches, btw.
Offline zwmalone
« Reply #19 on: Thu, 11 December 2008, 16:21:47 »
Quote from: lowpoly;14248
This board has a product code ofG80-3000LPCEU-0.  What does the "P" indicate for switch type?
Offline Chloe
  • Switch Kitten
« Reply #20 on: Thu, 11 December 2008, 16:27:24 »
P is black/linear.
Offline zwmalone
« Reply #21 on: Thu, 11 December 2008, 16:32:55 »
Thanks Chloe.  I guess I won't be buying that one.
Offline lam47
« Reply #22 on: Wed, 07 January 2009, 13:02:06 »
Im bumping an old thread I know but I have been asking cherry about these and this is the reply.
The blank ones are difficult to get hold of. They’re not normally carried in stock at all either here or in Germany and believe it or not, they actually charge us EXTRA to be able to get them. Their excuse, is that this costs an additional amount to stop the production line and pull the required stock out, but I’m not convinced…
On our system here, we’ve got the blank black version shown, but not the white, which means we’ve never bought them in. The black version has been purchased previously, but we have no stock at all. The trouble is, in order to get them, there is a minimum order quantity, which is generally 45pcs at a time. There is one further option for you. A company called ‘Devlin Electronics’ who are a distributor for Cherry’s keymodules, also manufacture their own keycaps. It’s possible that you may be able to get hold of a ‘standard’ G80-3000 and purchase a blank key-set from them For more info, try http://www.devlin.co.uk or call them on 01256 467367.
Hope this is useful!
Regards,
So looks like a no go unless you want to import from Japan which costs far too much for me :(
Offline Chloe
  • Switch Kitten
« Reply #23 on: Wed, 07 January 2009, 18:34:44 »
Thanks for the info. I was wondering what the minimum order quantity might be for a custom Cherry. I'd like a G80-18xx with blank keycaps.
Devlin don't make MX compatible keycaps like this:
Offline lam47
« Reply #24 on: Thu, 08 January 2009, 17:27:17 »
Its a shame as the white one in your original post looks lovely. Especially for a mac user (which I'm not but still it looks great)
Interesting that they have had one lot of the black blank ones.
I wonder who bought them?
Offline itlnstln
« Reply #25 on: Fri, 09 January 2009, 06:35:02 »
Quote from: Chloe;17420
I realized that the Dell AT101 does not have these "cylindrical" keycaps, and it does not bother me a bit as all my other keyboards have them (except for my ML4100), and I never even noticed.  Huh, live and learn.
