Author Topic: [IC] Cherry MX White switches  (Read 49491 times)
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: [IC] Cherry MX White switches
« Reply #150 on: Mon, 13 January 2014, 07:39:16 »
I'm interested as well. I'd pick up at least enough for a TKL and 60% board.
Offline jonathanyu
« Reply #151 on: Mon, 13 January 2014, 13:00:51 »
DCS please
I'm actually about to put in a very large order with our UK supplier - so could potentially increase that order quantity to make them even cheaper for you guys?
What will the price end up being?
Would need a rough estimate of how many switches you guys require before I can check.
I would probably interested for 200-300.  But it would depend on the price
« Reply #152 on: Mon, 13 January 2014, 13:31:45 »
I'd want 100. It's for a 60%, but that should be enough to cover any non-clicky ones.
  • Cherry Peasant
  • keycult.com
« Reply #153 on: Mon, 13 January 2014, 13:34:05 »
I hate having to think this way with whites. I recently bought 100 and only 43 or so clicked correctly.
« Reply #154 on: Mon, 13 January 2014, 13:36:16 »
Remind me not to go to Vegas with you.
Offline Photoelectric
« Reply #155 on: Mon, 13 January 2014, 13:54:12 »
Have you tried swapping stems among various housings?  I've read it might help with poorly clicking switches.
  • Cherry Peasant
  • keycult.com
« Reply #156 on: Mon, 13 January 2014, 14:00:57 »
The most common issue was hard clicking like a green. I fixed it with careful lubrication. Not sure how that will work long term though.
Edit: my lubing efforts
« Last Edit: Mon, 13 January 2014, 21:10:42 by riotonthebay »
Offline regack
« Reply #157 on: Mon, 13 January 2014, 16:44:34 »
I'd be interested in 100.
Offline lilky
« Reply #158 on: Thu, 23 January 2014, 13:43:14 »
Will the prices go down the more we buy? IE if we buy 10,000 will we go below $0.50 per switch? If so, count me in for ~100.
« Reply #159 on: Thu, 23 January 2014, 13:49:33 »
The problem is finding some to buy....
Offline Zeal
    • Zeal Generation Inc.
« Reply #160 on: Thu, 23 January 2014, 14:38:16 »
Finding a e-tailer that can find their stock...:P
Offline QWERTim
    • QWERKeys
« Reply #161 on: Thu, 23 January 2014, 15:00:16 »
I can get some but unfortunately they won't be as cheap as 50¢, even for 2000 as the next price break is nearer 5000.
« Reply #162 on: Thu, 23 January 2014, 15:05:56 »
The guys at mechanicalkeyboards.com say they will eventually have whites for sale.
^^ just repeating myself.....IF they get them they should correlate to the current pricing which would be ~$0.49 @ 100 switches w/free shipping CONUS.
Offline damorgue
    • Personal portfolio
« Reply #163 on: Thu, 23 January 2014, 16:30:51 »
Is there an ETA for that?
« Reply #164 on: Thu, 23 January 2014, 16:40:04 »
I will inquire and see if they have an ETA.
Offline DamienG
    • DamienG
« Reply #165 on: Sun, 26 January 2014, 16:51:20 »
The prices on that page are in GBP (British Pounds)...   so the 500 pieces price is 0.36 GBP = 0.59 USD.
[)amien
Offline QWERTim
    • QWERKeys
« Reply #166 on: Sun, 26 January 2014, 17:00:04 »
That is very cheap! If you buy from outside of the UK you won't have to pay VAT on that either!
Offline damorgue
« Reply #167 on: Mon, 27 January 2014, 10:14:16 »
Any news?
« Reply #168 on: Mon, 27 January 2014, 10:14:50 »
Any news?
Well he responded to my email but neglected to give me an ETA :(
I sent another with no reply.
Offline damorgue
« Reply #169 on: Mon, 27 January 2014, 10:20:32 »
Any news?
But he has confirmed that he will get them? Has he mentioned if they will be the same price as the other MX switches?
« Reply #170 on: Mon, 27 January 2014, 10:43:17 »
Any news?
I don't see why they wouldn't be the same price, but I'm speculating and all the confirmation is soon and/or eventually  :-X
Offline damorgue
« Reply #171 on: Mon, 27 January 2014, 10:46:35 »
Someone mentioned that Cherry's lead time is currently at 30-40 weeks because of the Logitech order. MX whites might also no longer be produced. I am considering twice as expensive sources atm.
« Reply #172 on: Mon, 27 January 2014, 10:47:58 »
Did Logitech make another large order? I know they were said to be affecting things a long time ago but I hadn't heard anything recently.
Offline damorgue
« Reply #173 on: Mon, 27 January 2014, 10:50:11 »
I don't know if it the same order, a continuation of the order or another one but Cherry are apparently busy for quite some time.
Offline Zeal
« Reply #175 on: Fri, 31 January 2014, 02:00:58 »
Devlin appears to sell MX White as well as some White MX Lock which I have never seen before.
Interesting that they say Whites are 65cN actuation. So they are lighter than greens  :eek:
There have been some variations of the MX Lock switch. The white translucent version is listed under MX Lock section of deskthority wiki.
Offline jonathanyu
« Reply #176 on: Fri, 31 January 2014, 02:01:10 »
I am not sure about the mx lock, but I think the MX "white" is just mx clear because it said Soft Tactile high force
Offline Zeal
« Reply #177 on: Fri, 31 January 2014, 02:04:48 »
Delvin lists the switch's actuation point for all the other colours, and clears actuation at 55cN. I think it's reasonable to say that Whites are indeed lighter than Greens due to the pre-applied lube/sound dampening stuff in it. :thumb:
Offline jonathanyu
« Reply #178 on: Fri, 31 January 2014, 02:08:28 »
but aren't mx white suppose to be Click Tactile?
Offline Zeal
« Reply #179 on: Fri, 31 January 2014, 02:19:39 »
MX Whites are considered soft tactile due to the switch being quieter than MX Greens.
MX Clears are simply called "tactile" under the Cherry MX Specsheet
The item code MX1A-Axxx also points to MX White according to this:
Offline jonathanyu
« Reply #180 on: Fri, 31 January 2014, 02:21:46 »
 :thumb: oh thank you, finally understand this
Offline damorgue
« Reply #181 on: Fri, 31 January 2014, 08:15:11 »
Yes, I actually checked the codes to verify that they were actually MX White. Now, who wants to contact them and nicely ask how many they have, at what price tiers and what their MOQ is?
The clear MX lock is just weird though.
Offline QWERTim
    • QWERKeys
« Reply #182 on: Mon, 03 February 2014, 04:43:37 »
They currently have 400+ in stock although I can tell you now, you're looking at more than £0.50/switch
« Reply #183 on: Mon, 03 February 2014, 06:54:22 »
which is ~$0.82
Offline QWERTim
    • QWERKeys
« Reply #184 on: Mon, 03 February 2014, 07:07:36 »
That'll be ex-VAT, sorry, forgot to mention that.
Offline damorgue
« Reply #185 on: Mon, 03 February 2014, 10:26:41 »
Well, I ordered from 7bit. I probably should have ordered more, but at least I have enough for a full board so that I can make an informed decision of what I think of them.
« Reply #186 on: Wed, 23 April 2014, 11:40:45 »
Offline DamienG
    • DamienG
« Reply #187 on: Sun, 27 April 2014, 14:36:19 »
They've had them for a while... but now have plate mount \o/
[)amien
« Reply #188 on: Sun, 27 April 2014, 14:40:49 »
[)amien
Not the whites those are new, they have had clears.
Offline yicaoyimu
« Reply #189 on: Sun, 27 April 2014, 16:24:22 »
Now I feel bad about selling 62x whites for $50... But that's what I paid for so I guess I don't need to feel bad.
Offline badman5
« Reply #190 on: Sat, 17 May 2014, 00:55:50 »
im interested in like about 12 for now. will buy at least 2
« Last Edit: Sat, 17 May 2014, 01:00:37 by badman5 »
Offline Zeal
« Reply #191 on: Sat, 17 May 2014, 01:06:17 »
Mechanicalkeyboards.com now stocks Cherry MX Whites: http://mechanicalkeyboards.com/shop/index.php?l=product_list&c=64
Offline Magna224
« Reply #192 on: Sat, 31 May 2014, 03:20:15 »
If the GB goes through id buy 60.  PM if it does ;)
« Reply #193 on: Sat, 31 May 2014, 08:00:27 »
This isn't going anywhere. You can buy mx whites from here http://mechanicalkeyboards.com/shop/index.php?l=product_list&c=64
