Author Topic: [IC] Cherry MX White switches  (Read 49491 times)
Offline Zeal
    • Zeal Generation Inc.
Re: [IC] Cherry MX White switches
« Reply #100 on: Sun, 13 October 2013, 13:10:54 »
Found a New York distributor/retailer? for a mix of Cherry MX Whites (Plate, Diode, PCB)
http://www.newyorksemi.com/index_part_en_MX1A11NN.phtml
They've got:
8759 Plate mounted ones by Cherry
86 Plate mounted ones by "PCherry"
402 PCB mounted ones by "unknown"
52923 PCB mounted ones by Cherry
402 Diode ones by Cherry
=62572 MX White switches. I know it's not near 100k nvm just read you were going to order ~10k haha., but there's about half of the MX White PCB mounted switches in there  :)
If everyone orders about ~100 switches, that's enough for 625 people  :p
Fingers crossed that the prices will be competitive. 50k PCB mounted switches :eek:
« Last Edit: Sun, 13 October 2013, 13:13:20 by Zeal »
Offline AKmalamute
  • HHKB Scrub
« Reply #101 on: Sun, 13 October 2013, 15:24:41 »
Quote from: Zeal
To quote WD40's slogan, "Just enough for a weekend."
HHKB-lite2, Dvorak user
Offline TLSC.wipeOut
  • "Who dares, wins"
« Reply #102 on: Sun, 13 October 2013, 20:23:53 »
They've got:
I hope we can use this as a viable source =D
OTD 456GT with Lubricated 68g Gold Spring MX Clears and GMK Dolch Keycap set
WTB: KMAC2 kit
Offline TheFlyingRaccoon
  • HHKB Pro
  • Cable maker and future engineer
« Reply #103 on: Sun, 13 October 2013, 20:30:10 »
They've got:
Great find! I submitted a RFQ. Fingers crossed they have good prices!
HHKB Pro 2   SmallFry Keyboard
  • "Who dares, wins"
« Reply #104 on: Tue, 15 October 2013, 21:38:55 »
They've got:
Any word on this TFR? =D
WTB: KMAC2 kit
Offline AlexJP
« Reply #105 on: Tue, 15 October 2013, 22:06:05 »
want 100~200 mx whites  ;D
Offline Reomero
  • Manual breather
« Reply #106 on: Thu, 17 October 2013, 23:50:42 »
Any updates? :-X
Offline Zeal
« Reply #107 on: Fri, 18 October 2013, 01:08:05 »
The suspense is killing me too  :-X
  • HHKB Pro
« Reply #108 on: Sun, 20 October 2013, 01:17:01 »
Apparently they do not have any in stock at the moment. The guy I talked to said he was would look into it for me.
Offline Zeal
« Reply #109 on: Sun, 20 October 2013, 01:54:40 »
What...62k Cherry switches don't just disappear into thin air  :eek:. Did you inquire about the plate ones too or just PCB mounted?
  • HHKB Pro
« Reply #110 on: Sun, 20 October 2013, 19:00:32 »
Yeah, that's why he's looking into it for me. :P I would like to get PCB mounted but would resort to plate mounted if they do not have any PCB mount.
  • "Who dares, wins"
« Reply #111 on: Sun, 20 October 2013, 21:46:33 »
bad warehouse inventory management? xD
WTB: KMAC2 kit
Offline agodinhost
  • Soylent green is people ...
    • Dr Ian O Xaman
« Reply #112 on: Mon, 21 October 2013, 08:12:36 »
+1
I would be interested in 200 or 300 depending on the price .
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #113 on: Thu, 24 October 2013, 14:21:49 »
so who's going to write the obituary for mx white switches lol
even if there are some left over mx whites sitting somewhere in a warehouse, its clear from cherry (if you guys are telling the truth) that white mx switches are dead and im almost sure its because of the inconsistent click. So...... RIP MX Whites.
btw whites with 45g korean springs are like the bomb, new favorite switch; lighter than blues with a different "muffled" click and perfect tactile bump.
Offline Zeal
« Reply #114 on: Thu, 24 October 2013, 14:30:36 »
STAHP. I need to get my hands on some MX Whites before they go extinct! - Twirls thumbs while we wait for TFR to update us-
What causes the inconsistent click? Is it just poor lubing?
Offline Glod
    • YouTube Channel
« Reply #115 on: Thu, 24 October 2013, 14:34:36 »
its probably the lubing, i have played around with re-lubing white switches and its pretty easy to destroy its ability click (and the tactile bump) with lubing areas around the slider too much
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #116 on: Thu, 24 October 2013, 14:37:00 »
I guess its kinda like lubing a blue switch stem to much?
« Last Edit: Thu, 24 October 2013, 14:44:00 by Signature »
Offline Zeal
« Reply #117 on: Thu, 24 October 2013, 14:42:48 »
If it doesn't click, then why not just rinse the lube out and use it bare/re-lube it?
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #118 on: Thu, 24 October 2013, 14:44:36 »
Aint anybody got time for that^
Offline Glod
    • YouTube Channel
« Reply #119 on: Thu, 24 October 2013, 14:46:40 »
yeah correct. the stems are VERY similar
well depends how you go about that, i don't think rinsing is a good idea, wiping off the best you can maybe. you wont totally be able to lube it the same way as the cherry machines did unless someone discovers the exact way and material it is done with.
« Reply #120 on: Thu, 24 October 2013, 14:49:03 »
I believe it is a very light amount of lube, I just can't get used to whites, I want to like them.
Offline Glod
    • YouTube Channel
« Reply #121 on: Thu, 24 October 2013, 14:50:48 »
i only like my mx whites modified :D
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #122 on: Thu, 24 October 2013, 14:53:32 »
IF i got it right the mx White is just a lubed mx green? Why don´t you just lube your greens + you get your consistant click :rolleyes:
Offline Glod
    • YouTube Channel
« Reply #123 on: Thu, 24 October 2013, 14:55:38 »
there could be some difference other than lubing, i just don't have the correct measurement tools and i don't have green switches as well.
but i bet ya someone on DT/Geekhack/Reddit has already performed the research lol.
Offline Zeal
« Reply #124 on: Thu, 24 October 2013, 15:03:25 »
The bottom out force required for whites is about 10cN less than greens. Could be a different spring or just the lube., can't remember. The sound is definitely different, and I'd prefer a subtle click than a high pitched one from blues/greens.
SpAmRaY, that QF TK? of yours, is it a CM prototype or did you mod it? I recall someone saying CM made a protoype board with whites last time I made a thread about MX Whites... And you sold it :( Damn.
« Last Edit: Thu, 24 October 2013, 15:08:07 by Zeal »
« Reply #125 on: Thu, 24 October 2013, 15:06:52 »
Ripster claims the legs are different but everyone else seems to think they are the same. There has been speculation the slider part is made of a slightly different material as well.
For me using green and white boards back to back, I definitely preferred white but I just like clears at the end of the day. I've had many people say greens and whites feel the same but to me the whites are much smoother, probably due to lube, and greens seem to have a sharper click and for some reason I found greens fatiguing.
SpAmRaY, that QF TKof yours, is it a CM prototype or did you mod it? I recall someone saying CM made a protoype board with whites last time I made a thread about MX Whites.
It's not a QF TK it is a fullsize XT and it is a factory prototype/sample. Carter said he couldn't tell enough difference between white and green to warrant recommending they produce boards with whites.
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #126 on: Thu, 24 October 2013, 15:08:47 »
I see but if you would have lubed greens it would be a clickier white?
« Reply #127 on: Thu, 24 October 2013, 15:15:57 »
To me, MX White switches feel like lubed MX Greens.
Offline Zeal
« Reply #128 on: Thu, 24 October 2013, 15:16:44 »
So... SpAmRaY secretly has connections with CM?!  :p
« Reply #129 on: Thu, 24 October 2013, 15:18:06 »
No I bought it from the classifieds, you just have to know where to look  :p
Offline taylordcraig
« Reply #130 on: Sat, 16 November 2013, 18:06:18 »
I'd be interested in 150 switches.
Offline divito
« Reply #131 on: Sat, 16 November 2013, 18:15:56 »
Hmm, even more intriguing.
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
Offline catnipz0098
« Reply #132 on: Sat, 16 November 2013, 18:36:20 »
Interested
« Reply #133 on: Sun, 17 November 2013, 06:22:30 »
The guys at mechanicalkeyboards.com say they will eventually have whites for sale.
Offline AlexJP
« Reply #134 on: Sun, 17 November 2013, 08:46:54 »
definitely want  :thumb:
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #135 on: Sun, 17 November 2013, 09:45:08 »
Well I just received my switch tester the other day. Whites feel like a softer blue switch ? I think..
Offline fart_toast
« Reply #136 on: Sat, 14 December 2013, 04:48:38 »
nope
Dammit I just ordered 100 ish from 7bit and live in the UK..could have got them for 0.39GBP and delivered quicker from Conrad as I live in UK. Fail!!!!!
Offline joneslee85
  • HHKB Scrub JP
  • Professional Rubyist programmer!
    • Ruby Journal
« Reply #137 on: Sat, 14 December 2013, 04:53:39 »
Interested if we could work out a cheaper deal than 7bit
TOO MANY KEYBOARDS THAT I COULD NOT COUNT! BUT I AM STILL USING MY MODEL F77
Offline shawn o
« Reply #138 on: Thu, 09 January 2014, 12:24:29 »
I'd order 130.
Offline AlexJP
« Reply #139 on: Thu, 09 January 2014, 19:08:00 »
120 for me
Offline JayKthnx
« Reply #140 on: Thu, 09 January 2014, 20:18:38 »
If be in for 200.
Offline DelKey
« Reply #141 on: Sat, 11 January 2014, 09:43:10 »
I'd be interested in 100 or maybe 200'
Offline regack
« Reply #142 on: Sat, 11 January 2014, 09:50:41 »
Is this going anywhere, because I'd be interested.
« Reply #143 on: Sat, 11 January 2014, 10:03:43 »
I don't think so....the best info I had was
Offline QWERTim
    • QWERKeys
« Reply #144 on: Mon, 13 January 2014, 05:02:12 »
I'm actually about to put in a very large order with our UK supplier - so could potentially increase that order quantity to make them even cheaper for you guys?
Offline damorgue
    • Personal portfolio
« Reply #145 on: Mon, 13 January 2014, 05:18:46 »
What will the price end up being?
Offline QWERTim
    • QWERKeys
« Reply #146 on: Mon, 13 January 2014, 05:22:51 »
Would need a rough estimate of how many switches you guys require before I can check.
Offline damorgue
« Reply #147 on: Mon, 13 January 2014, 05:29:41 »
I'd get at least enough for one keyboard, possibly two. Based on the length of this thread there are a few others in a similar situation.My guess is that there is interest for at least 1000pcs, more if the price is better.
Offline QWERTim
    • QWERKeys
« Reply #148 on: Mon, 13 January 2014, 06:23:12 »
Those numbers should be do-able. Will ask our suppliers for a quote.
« Reply #149 on: Mon, 13 January 2014, 07:28:39 »
I'm still interested in these. Please let us know what you find! XD
