Author Topic: Cheapest not awful O-Rings.  (Read 3099 times)
Offline acer589
  • Gotta get out of college
« on: Tue, 01 October 2013, 13:19:26 »
So, My keyboard is a little loud to bring to work, and I was wondering where I could get the cheapest non-awful O-Rings.
MX Blue Black Widow Ultimate    MX Black Quickfire Rapid TKL    MX Black Poker II
Offline Photoelectric
Re: Cheapest not awful O-Rings.
« Reply #1 on: Tue, 01 October 2013, 13:23:51 »
$8.25 50A black o-rings from Amazon.  The best universal o-rings I've used for sound dampening.
http://www.amazon.com/dp/B0051XWXCE/ref=biss_dp_t_asn
Otherwise, some people use dental bands.
Offline JPG
  • Model F is my new passion!
« Reply #2 on: Tue, 01 October 2013, 13:24:14 »
That's the ones I use (008 dash size):
http://www.amazon.com/008-Buna-N-O-Ring-Durometer-Black/dp/B003SLE5KO/ref=sr_1_3?ie=UTF8&qid=1380651714&sr=8-3&keywords=o-ring+008+70A
There's other options (people typically prefer 50A or even 40A), but on amazon they cost more for this size. Personnaly I really like my 70A. At less than 2$ a bag of 100, it's worth a try, more so if you're in the US and shipping is much less than int.
Offline Tarzan
  • formerly known as Greystoke
« Reply #3 on: Tue, 01 October 2013, 13:24:41 »
Offline Grim Fandango
« Reply #4 on: Fri, 04 October 2013, 04:59:41 »
Just a general tip, put something under the keyboard. Anything from a piece of towel to a mousepad will in most circumstances reduce the sound from typing a lot. It will take out some of the thump from bottoming out and sounds will not resonate on your desk.
Offline kaotikb
« Reply #5 on: Sun, 06 October 2013, 11:28:02 »
I have a piece of anti slip mat that you use under rugs so they dont slip.Works pretty well and keeps the keyboard from moving. You can also get one of those big mouse/desk pads.
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Offline SNF
« Reply #6 on: Wed, 09 October 2013, 04:37:40 »
I have some 50A black o-rings that I could send you for a good deal.
I fully crossed over to topre and won't be needing them.
PM me if interested  :thumb:
