Author Topic: The Model M 1391401 is pulling me away from my ergo boards  (Read 2574 times)
Offline vivalarevolución
« on: Tue, 01 October 2013, 20:01:38 »
I'm not sure how I feel about this development.  I love my ergo boards.  But the solid feel of the 1391401 is causing some deep changes in my keyboard preferences.  I might have to retreat into the depths of my mind and do some serious introspection about priorities.
I did not feel this way about 52G9658, and I parted with that board without a struggle.  IBM did it right with the 1391401.
When I get my converter working for my F122, I'm afraid the ergo boards will be furloughed, and it will have nothing to do with a government shutdown.
I'm scared.  Changes are happening that are making me uncomfortable.
Re: The Model M 1391401 is pulling me away from my ergo boards
« Reply #1 on: Tue, 01 October 2013, 20:20:46 »
Like driving a pickup truck after years of sports compacts.
- D Trump 2026-09-28
Offline Tony
« Reply #2 on: Tue, 01 October 2013, 20:45:01 »
Take a deep breath and relax. Polygamy is allowed.
« Reply #3 on: Tue, 01 October 2013, 20:59:44 »
I have a lexmark made 1391401 from 1992 and it's not THAT much more solid (compared to my modern unicomp). I much prefer my 1390120 from march 1986.
That said, I do enjoy my buckling springs (of any sort), and completely understand. For a week or so I put away my ergoDOX and brought out said 1390120. I ended up leaving the M at work and forcing myself to make do with the ergodox at home 'cause it's good for me (I'm finally learning proper typing habits)
« Reply #4 on: Tue, 01 October 2013, 21:12:47 »
The pre-Lexmark 1391401's have a heavier plate, right?
« Reply #5 on: Tue, 01 October 2013, 21:53:31 »
the heavy plates stopped about early-1989
« Reply #6 on: Tue, 01 October 2013, 22:42:27 »
IBM certainly did do something right with the Model M!
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #7 on: Tue, 01 October 2013, 23:03:35 »
This is how I feel but reverse with my HHKB.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline heissler
  • I engineer invisible stuff
« Reply #8 on: Wed, 02 October 2013, 01:40:05 »
Traitor! Quick, hide before the staggered wrath of tp4 strikes thee who turned themselves away from the almighty Dox!
Has trouble not spending money on keyboards
Offline tipo33
  • "Ski"
« Reply #9 on: Wed, 02 October 2013, 04:34:55 »
YES!  I knew I lit a flame :D
KM4COL    R.I.P.  SmallFry
Offline 1391406
« Reply #10 on: Wed, 02 October 2013, 08:08:35 »
I'm not sure how much the heavier plates contribute to the overall weight of the keyboard, but I can't detect any noticeable difference in weight between my 1987 and 1992 Model M's, both of which were manufactured by IBM. The keys of the '87 are a little stiffer to type on but that's another story.
Offline ch_123
« Reply #11 on: Wed, 02 October 2013, 08:12:43 »
The original heavy tempered steel plates disappeared some time between 87 and 89 (they probably switched in 87, and used up the stock as they went along, this is probably why you also see a mixture of Ms that have wire stabilizers on the vertical keys, and those which have the black stabilizer inserts in the barrels). I think they also thinned the plates again when they brought out the 42H1292 in the mid 90s as Ms lost about 200g in weight around then.
« Last Edit: Wed, 02 October 2013, 08:15:22 by ch_123 »
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #12 on: Wed, 02 October 2013, 08:58:21 »
Do you know if there is also a difference between early ssks and later ones? They first appeared in 87, so I wonder if there are differences.
« Reply #13 on: Wed, 02 October 2013, 11:32:07 »
I was wondering this exact same question and considered starting a new thread on it.
Offline ch_123
« Reply #14 on: Wed, 02 October 2013, 11:44:11 »
I've never seen an SSK with the older style plate, and given that the thin plates appeared in 1987, I'd say that they may have just used the new style with the SSK.
EDIT: Managed to put the reply in the quote box :D
« Last Edit: Wed, 02 October 2013, 11:55:24 by ch_123 »
