Author Topic: Anyone got the Q-Pad MK 85?  (Read 1639 times)
Offline mini66
« on: Wed, 02 October 2013, 08:44:49 »
Hello do you have to install the software to get the keyboard to work as I have no need for them right now but I will in the future...?
Offline RabRhee
Re: Anyone got the Q-Pad MK 85?
« Reply #1 on: Wed, 02 October 2013, 09:00:59 »
No, the software is only if you want to use the macro stuff. My sister has my old one and never installed the software, it works fine, the LED options work as well.
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline mini66
« Reply #2 on: Wed, 02 October 2013, 09:06:44 »
Thank you
Offline mini66
« Reply #3 on: Wed, 02 October 2013, 11:13:42 »
Thanks for all your help! I've decided to go for a 85, with MK red keys for gaming, they have come down in price too :)
Offline RabRhee
« Reply #4 on: Wed, 02 October 2013, 12:43:35 »
You did say on your other post that you wanted blue LEDs, well the 85 that I have, and that I have seen, are all red LED. Its the 80 that is blue LEDs
Offline mini66
« Reply #5 on: Wed, 02 October 2013, 12:55:50 »
Thanks I changed my mind as I might want to use the programmable in the future...
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #6 on: Wed, 02 October 2013, 20:41:07 »
The Q-pad and the nighthawk looks exactly the same except the nighthawk x8 has NKRO I don't know about the Q-pad
Offline mini66
« Reply #7 on: Thu, 03 October 2013, 14:12:18 »
I've got a mx red q-pad 85 and I wouldn't say it was quite! Does anyone else agree with me about this keyboard??
Offline C5Allroad
« Reply #8 on: Thu, 03 October 2013, 16:38:23 »
Quieter than blues.... It's loud if you bottom out. You might want to consider o-rings.
Offline mini66
« Reply #9 on: Fri, 04 October 2013, 09:14:52 »
You might want to consider O-rings
Where would I buy them in the UK?
