Author Topic: Kinesis Classic PS2 to USB  (Read 5253 times)
Offline kaltar
« on: Wed, 02 October 2013, 21:05:59 »
Here is my 2002 Kinesis Classic PS2 modded to be USB only. Posting the process in next post.
37611-037613-1
« Last Edit: Thu, 03 October 2013, 12:50:38 by kaltar »
Offline kaltar
Re: Kinesis Classic PS2 to USB
« Reply #1 on: Wed, 02 October 2013, 21:17:21 »
I got the Switchcraft Panel Mount Connector - USB B to A in sweetwater
http://www.sweetwater.com/store/detail/EHUSBBAB/, and ID INNOVATIONS MULTIMODE USB ADAPTER sold by mkawa http://geekhack.org/index.php?topic=48030.0
I used the USB adapter intact, so I can replace it later If I wish.
37617-0
Step 1: open the keyboard:
37619-1
step 2: remove the cable from the casing, and use a step drill to make a hole until the USB connector fits
37621-2
step 3: mark the areas for the screws to be drilled
37623-3
37625-4
step 4: drill the holes
37627-5
Now, since the original screws had no nuts, I had to replace with something I already had at hand. Luckily, found some black screws that fit on some type of nuts :)
37629-6
Step 5: Screw the panel from the inside
37631-737633-8
« Last Edit: Wed, 02 October 2013, 21:24:06 by kaltar »
Offline kaltar
« Reply #2 on: Wed, 02 October 2013, 21:23:17 »
Now, the point of no return:
Cut the original PS2 cable, and keep the parts shown
37635-0
Glue together the ground and black cable
37637-1
Solder the cables together, only the PS2 cable ones, the others go to the Pedals, and I have future plans for those.
The Laffy Taffy is in top of those pedal cables.
37639-2
37641-3
Put it back together, with the PS2 converter. (You can see my cables from doing sordna's palm keys modification http://geekhack.org/index.php?topic=26579.0)
37643-4
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #3 on: Thu, 03 October 2013, 05:00:17 »
 :thumb: great use of the adapter. i was hoping people would integrate them into old ps2 boards. the sskrs will all be usb without major controller modification thanks to these adapter chips.
love the laffy taffy :P, but i hope that's actually more hot glue
Offline kaltar
« Reply #4 on: Thu, 03 October 2013, 12:53:35 »
The only issue I've seen with the adapter is the control of the caps-lock light. other than that, it's perfect (and so small).
The laffy taffy is for my digestion only after the mod is complete :)
Offline sordna
« Reply #5 on: Fri, 04 October 2013, 20:17:59 »
Haha, I see the step drill bit is getting plenty use, not just palm keys but also this :-)
Offline kaltar
« Reply #6 on: Fri, 04 October 2013, 21:25:40 »
Yes, it's so damn useful! Thanks for the tip sordna!
