Author Topic: Das Ultimate or Filco  (Read 4798 times)
Offline Al3xG
« on: Thu, 03 October 2013, 11:37:53 »
Hi to all! I need to buy my first mechanical keyboard, and I've to choose from the Das Ultimate (new for 150€ shipped) and the Majestouch 1 (used for 110€ shipped).
For me the Das id more good looking, but the Filco seems more robust.
for those who have tried them both, which do you recommend?
Thanks  ;)
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Das Ultimate or Filco
« Reply #1 on: Thu, 03 October 2013, 11:39:14 »
Both are nice keyboards but from those choices I would go filco. Other good keyboards are CM Storm, Ducky, WASD.
-Enzo Ferrari
« Reply #2 on: Thu, 03 October 2013, 11:42:39 »
They both great, but the Filco I'm using right now wants you to buy a Filco.
Offline yasuo
  • spanengan puyeng newbie
« Reply #3 on: Thu, 03 October 2013, 11:58:44 »
design das more modern and looks glossy body
Logitech MK220 Colemak DH
Offline BliTzKiN
« Reply #4 on: Thu, 03 October 2013, 12:18:35 »
Filco gets my vote, I'm not really a fan of the glossy finish and the weird shape above the numpad
Offline acer589
  • Gotta get out of college
« Reply #5 on: Thu, 03 October 2013, 12:26:25 »
Yeah, I would definitely go for the Filco. Quality of Das has gone down recently.
MX Blue Black Widow Ultimate    MX Black Quickfire Rapid TKL    MX Black Poker II
Offline Al3xG
« Reply #6 on: Thu, 03 October 2013, 15:27:16 »
The Das Ultimate isn't made by Costar, like Filco?
Offline ch_123
« Reply #7 on: Thu, 03 October 2013, 16:43:06 »
A friend of mine recently sold his Das to buy a Filco due to (amongst other things) the Das' glossy finish attracting too much dust.
Offline dante
« Reply #8 on: Thu, 03 October 2013, 16:47:40 »
Neither.
DAS for the reasons already stated.
Per EK the Filco Maj-1 may have controller issues down the road.
Filco Maj-2? No contest.
Offline Al3xG
« Reply #9 on: Thu, 03 October 2013, 17:22:22 »
Neither.
So do you recommend a Majestouch 2? I don't understand...
Offline xCatbodi
« Reply #10 on: Thu, 03 October 2013, 17:23:35 »
I just canceled my Das Ultimate because of them changing their OEM's from what I had heard.
Offline ComradeSniper
  • HHKB Pro
« Reply #11 on: Thu, 03 October 2013, 17:25:01 »
I don't believe that the latest generation is.
I'd recommend Filco as well, I don't think there's a better quality non-custom board available right now than a Majestouch 2.
« Reply #12 on: Thu, 03 October 2013, 17:31:08 »
Das has seemed a bit gimmicky to me.  Plus that gloss!
Offline Al3xG
« Reply #13 on: Thu, 03 October 2013, 17:43:06 »
Is only for the Professional if I'm not wrong...
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #14 on: Thu, 03 October 2013, 19:55:45 »
...I don't even know what to say to that....
The Filco looks nicer you won't to clean that everyday if you like your things looking nice.
Offline Emospence
« Reply #15 on: Thu, 03 October 2013, 20:17:43 »
Filco or CMStorm Rapid/XT  ;D
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Offline dante
« Reply #16 on: Thu, 03 October 2013, 21:17:15 »
Filco.
Although I've had zero issues with either of my QFR's the number of defects per Newegg/Amazon reviews is alarming.
Offline PadawanGeek
« Reply #17 on: Thu, 03 October 2013, 21:40:32 »
I've heard that the glossy surface not only attracts dust, it's a fingerprint magnet as well.....prolly spend half the day spit and polishing it just to keep it looking good. MJ2 no contest, love my MJ2's! ;D
Offline Lu_e
« Reply #18 on: Thu, 03 October 2013, 22:05:18 »
Gloss plastic scratches, that's the worst thing about it IMO
Just say NO to ABS keycaps
Offline Belfong
« Reply #19 on: Thu, 03 October 2013, 22:32:06 »
Yeah, I think the glossy surface ie fingerprint magnet in the DAS is a put off.
But then, Filco is used.
So why not go with WASDkeyboards? Their V2 is really solid. And you can choose the colour of your key caps and customize them. And they cost slightly more than DAS.
I am using the Code from WASD and loving it.
Offline IMHB
« Reply #20 on: Fri, 04 October 2013, 00:54:39 »
if they're all mx blue, take filco. It's a classic.
But consider other brands too like QFR.
Offline mapple
« Reply #21 on: Fri, 04 October 2013, 02:53:00 »
go with filco for quality
In God We Trust
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #22 on: Fri, 04 October 2013, 03:01:27 »
My take on this would be to get the Filco over the Das.  Unless the Das is an older Costar version then it could go either way.  There was some quality questions that were called upon when Das added the media keys which to my knowledge were not Costar board and again when the news of changing OEMS surfaced.
Offline Al3xG
« Reply #23 on: Fri, 04 October 2013, 03:51:04 »
Ok, I'm going with Filco  ;)
Today I've found a very little used Majestouch 2 Camo for a very good price (less than the used Majestouch 1), but I don't like the Fn button.
What do you recommend?
« Reply #24 on: Fri, 04 October 2013, 04:16:34 »
You're kinda stuck - the Fn key is the Fn key and that is that.
If you don't like that, you'll have to find a different keyboard.
Offline Melvang
« Reply #25 on: Fri, 04 October 2013, 04:23:08 »
at least not without replacing the controller.
Offline Al3xG
« Reply #26 on: Fri, 04 October 2013, 04:53:06 »
Where I can find the alternative controller?
Offline Melvang
« Reply #27 on: Fri, 04 October 2013, 04:54:49 »
That I am not sure but will require desoldering and soldering some fairly tiny stuff.  By tiny I mean about 1/4 the size of a pad for a standard keyswitch.  I know it is possible but not sure where or which controller to source for the filco.  Also keep in mind that you will also have to create a custom firmware and flash it to the new controller before said keyboard will work.
« Reply #28 on: Fri, 04 October 2013, 05:12:04 »
This is a lot of work to modify the keyboard - are you sure you can't find an alternative keyboard that has the layout that you would prefer?
Offline Grim Fandango
« Reply #29 on: Fri, 04 October 2013, 05:14:56 »
I would go for the Filco. I just do not like glossy on a keyboard. Sets of my OCD with the smudges and fingerprints non-stop. That said, is it not possible to get a Majestouch 2 for that price if you look in the classified?
« Reply #30 on: Fri, 04 October 2013, 06:35:20 »
Offline atlas3686
  • HHKB Elite
« Reply #31 on: Fri, 04 October 2013, 07:06:05 »
I have 2 Filco's now (brown fullsize and black TKL) and they are brilliant. I have heard that the Das quality has gone down a bit recently and they are serious fingerprint magnets apparently. Got mine from thekeyboardco.com
Offline therecorder
« Reply #32 on: Fri, 04 October 2013, 07:44:16 »
I have 5 filcos and a Das Ultimate.  They're all very nice keyboards.  But, the Das has Blanks, 2 USB slots, and (imho) feels and sounds nicer (probably because of the different keycaps and a tiny bit of play in the keystroke).  If you can deal with the shape and the finish, and are looking to save a little money, I'd say go with the Das.
Offline Al3xG
« Reply #33 on: Fri, 04 October 2013, 08:36:49 »
http://geekhack.org/index.php?topic=46700.0
WOW!!! I've just buyed the Majestouch 2 camo  ;)
Offline Danule
« Reply #34 on: Fri, 04 October 2013, 08:53:55 »
i have a costar das and 2 filco's i prefer the filco, feels about the same maybe a bit more solid, the filco MJ2 has a better PCB which i like.
45g Brown Brown Blue
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #35 on: Fri, 04 October 2013, 09:51:52 »
Filco. Or better yet, go with the Topre Realforce, but if that is your two choices go with Filco. Not only is it a well built board, but Das boards are almost equivalent to "gaming" boards like the Razer BWU. Most people who buy it don't know that much about keyboards.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline foxtrott
« Reply #36 on: Fri, 04 October 2013, 12:08:30 »
that is not easy to answer ..  filco is very good.. but DAS is beautiful..  best buy both ..  :D ;D
