Author Topic: Cheap Keycaps  (Read 2543 times)
Offline xCatbodi
Cheap Keycaps
« on: Thu, 03 October 2013, 16:44:56 »
Where can I snag some high quality cheap keycaps?
I just ordered a QuickFire Rapid from Amazon (Browns).
I really would prefer spending less then $40.
I was thinking of buying the full set from EliteKeyboards for $30, black. Do I need anything else to install them?
Re: Cheap Keycaps
« Reply #1 on: Thu, 03 October 2013, 17:12:39 »
If you mean the pad printed ones, they are reasonable, but pad printed (meaning the legends will wear off sooner rather than later).  Unless you are considering getting the blank ones.
Actually I had the printed green set from EK on my QFR for a while - they are surprisingly good (but still only pad printed, and fairly thin).
Or Vortex? $33 in the GB if you can stand the legends.
Offline xCatbodi
Re: Cheap Keycaps
« Reply #2 on: Thu, 03 October 2013, 17:13:45 »
Whoopsie, forgot to mention I 100% for sure want the blank ones.
Offline kaotikb
Re: Cheap Keycaps
« Reply #3 on: Thu, 03 October 2013, 17:33:05 »
there is these : http://www.banggood.com/POM-87-Set-Blank-Key-Caps-Black-Keycaps-For-Cherry-MX-Keyboard-p-84081.html
I don't know if they are any good or fit the board. But yeah they are very cheap.
Ducky 1087 (Green ALPS) |  CM QFR Stealth (MX Brown) | Unicomp Ultra Classic |Poker II (MX Brown)  | IBM 1391401 1991 | IBM 1391401 1989 | Ducky Shine 3 White Edition (MX Brown) | G80-3700(MX Black) | Corsair K70 (MX Brown) | Varmillo VA87MR (Gateron Red)
Pointing Devices:  Microsoft Trackball Optical (Ceramic bearings Installed)  | Sanwa MA-TB39BK (Larger Ceramic Bearings Installed) | Elecom M-XT2URBK | Kensington Slimblade | Logitech Trackman Wheel | Logitech Trackman Marble Plus
Re: Cheap Keycaps
« Reply #4 on: Thu, 03 October 2013, 17:33:19 »
Then the EK ones will be good to get you started.
Depending on how much you use the keyboard they will probably shine fairly quickly, but at that price it doesn't really matter.
During the meanwhile you can look around and maybe find something else you'd like too.
Offline acer589
  • Gotta get out of college
Re: Cheap Keycaps
« Reply #5 on: Thu, 03 October 2013, 18:04:29 »
The banggood ones are pretty good.
MX Blue Black Widow Ultimate    MX Black Quickfire Rapid TKL    MX Black Poker II
