Author Topic: Poker X not working  (Read 1517 times)
Offline IMHB
Poker X not working
« on: Thu, 03 October 2013, 18:25:39 »
Today I just changed my poker x into the aluminum case...but after I used it for around 10 minutes, it stopped working....
I did put a layer of electric tape on the bottom of the case and also put a layer of thin plastic foam between the case and the PCB....now when I plug it in, only the cap led flashes and nothing else works anymore.....
sighhh wondering if this poker is broken or not...
Offline jonathanyu
Re: Poker X not working
« Reply #1 on: Thu, 03 October 2013, 19:10:42 »
try to switch it back to the original plastic case, so that you can know is the case problem or something else
Offline IMHB
« Reply #2 on: Thu, 03 October 2013, 22:57:23 »
yea it's not the pcb's problem...the pcb works perfectly after i get it out of the case....trying to solve this problem now..
« Reply #3 on: Fri, 04 October 2013, 00:25:37 »
Look around the USB-jack area. If you accidentally shorted something, it can easily cause that issue (not working after a few minutes) and is harder to tape off since it sticks out some.
Offline Loligagger
« Reply #4 on: Fri, 04 October 2013, 00:40:03 »
Could just be a poor connection with the USB cable. I've had something similar occasionally happen with my poker but just unplugging/replugging it would fix it.
Offline Photoelectric
« Reply #5 on: Fri, 04 October 2013, 00:44:51 »
Perhaps you need some electrical tape over the inner sides of the case as well?
Offline IMHB
« Reply #6 on: Fri, 04 October 2013, 01:00:13 »
I do have the inner part of the case taped...but anyways I fixed this problem...by loosen up the screws a little...
yea I tried carefully when it's connected, if i screw all screws in tightly the keyboard will start just malfunctioning and spazzing all letters at once..but I loosened up them and now they're just fine!
thanks everyone.
« Reply #7 on: Fri, 04 October 2013, 01:05:39 »
Sounds like the CM QFR problem: some cases were overtightened during assembly and had trouble registering some keystrokes until they were loosened a bit.
Offline IMHB
« Reply #8 on: Fri, 04 October 2013, 01:08:21 »
yes but the thing is, when I took the PCB off from the original poker case, it was screwed in extra-tight....
maybe it's the inner solid design of the aluminum case..because the original case has empty spaces below the PCB while the aluminum case is just a solid plate below it.
