Author Topic: Anywhere to get the aluminum feet?  (Read 1900 times)
Offline IMHB
« on: Fri, 04 October 2013, 11:11:17 »
For the aluminum feet, I have a quick question...
currently I got my poker x into an aluminum case, but the case is flat, and I do not like my keyboard completely flat on the table, so I decided to buy some aluminum feet.
wondering where can i get some and how do they work...like do they simply have a stick on their back or if I need to screw them in or.....
I've been looking at these ones but tsangan hasn't got back to me yet.....
http://geekhack.org/index.php?topic=44764.0
Re: Anywhere to get the aluminum feet?
« Reply #1 on: Fri, 04 October 2013, 11:13:40 »
They screw in, so the case needs holes for them. You can buy them from kbdmod.co.kr (not sure if you'd need a proxy, i've heard you can email them directly to have them ship outside of korea)
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #2 on: Fri, 04 October 2013, 11:31:13 »
Search google for GON keyboard works and you'll find the feet listed there as well, probably a bit easier to deal with than kbdmod.
« Reply #3 on: Fri, 04 October 2013, 11:52:09 »
Offline IMHB
« Reply #4 on: Fri, 04 October 2013, 14:05:26 »
thanks guys...but I just realized my aluminum case does not have holes for feet.....
guess I'll have to buy some cheap tall rubber feet and glue them on....
Offline bueller
  • MX baller
« Reply #5 on: Fri, 04 October 2013, 22:44:41 »
