Author Topic: What switch would you recommend?  (Read 5528 times)
Offline dragonxx21
« on: Sun, 06 October 2013, 03:15:01 »
Hey guys, I'm currently trying to design a custom keyboard, and I'm interested in your thoughts about what switch I should use. I know that I should be choosing a switch based on my own preferences, but I'm still interested in what you would recommend. For now, I'll have to limit it to Cherry MX switches, but I am open to different variations of switches, eg. Ergo Clears, Jailhouse Blues, etc. Also, I want to try something new, so blues are off the list. Show me what you've got GH. :D
Poll: http://strawpoll.me/509888
If other, please suggest it in the thread.
« Last Edit: Sun, 06 October 2013, 04:04:09 by dragonxx21 »
Keyboards Owned:
Realforce Topre 91 Key JIS Profile - Main
CM Quickfire Rapid Blue Switches
IBM Model M in Industrial Shell
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
Re: What switch would you recommend?
« Reply #1 on: Sun, 06 October 2013, 03:16:18 »
Panda clears emulate topre most successfully i hear.
Having a bad day?
Offline dragonxx21
« Reply #2 on: Sun, 06 October 2013, 03:22:35 »
I'm pretty meh about topre. Never tried it, I'm sure I'd like it, but all I can say is "meh".
Keyboards Owned:
Offline mauri
« Reply #3 on: Sun, 06 October 2013, 03:37:34 »
Recommend? I think you mean raffle?
I AM BABAR KING OF THE ELEPHANTS
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #4 on: Sun, 06 October 2013, 03:42:11 »
You are only meh because you havent tried it.
Once one ness with cup rubber grasps you, it does not let go.
Having a bad day?
Offline dragonxx21
« Reply #5 on: Sun, 06 October 2013, 03:49:05 »
Let's not turn my thread into a topre circle jerk. I have no desire whatsoever to get a topre board, or to simulate a topre board any time in the near future. I hate to sound like a total d**k but I'm not interested in all the 'thopre' hype.. With that in mind, I will consider Panda Clears, although I feel as if they may be a little heavier than I'm used to.
What do you mean?
Keyboards Owned:
Offline mauri
« Reply #6 on: Sun, 06 October 2013, 03:50:23 »
What do you mean?
How can someone recommend something when nobody knows what kind of switch do you like, I could just as well dumb every switch known to man here and say pick one :d
Offline dragonxx21
« Reply #7 on: Sun, 06 October 2013, 03:54:28 »
I'm simply interested in opinions. I want to know what works for people and why. I don't have access to every single type of switch, and I'm not able to test out every type of switch. If you really must know what I like then I'd like to tell you that I don't know what I like. I've used two switches (technically three), reds, blues, and blacks. I use the blues daily and I like the audible click, bump and low actuation force. The reds are also nice but I do not like linear switches as much as tactile ones. The blacks felt a tad bit too heavy but I feel like I could adjust.
Keyboards Owned:
Offline mauri
« Reply #8 on: Sun, 06 October 2013, 03:56:42 »
Like tactile, dislike linear now we're talking.
MX white perhaps? Kinda like blue, tad bit heavier than blues but lighter than blacks.
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #9 on: Sun, 06 October 2013, 03:57:53 »
I hear cherry MY is a good switch...
Having a bad day?
Offline phoenix1234
« Reply #10 on: Sun, 06 October 2013, 03:58:20 »
IMO,
You can try :
+ Red Stem + Clear Spring => lighter than Clear but the bottom out is very strong
+ Blue stem + Black Spring  => Very close to Cherry MX Green (98%)
+ Stock Cherry MX Red => Well, the smoothest switch from Cherry
+ Clear Stem + Red Spring => Ergo Clears more or less
You shouldn't try:
+ Red Stem + Black Spring
+ Blue stem + Clear Spring => Weird feeling
I like linear switches
Offline ComradeSniper
  • HHKB Pro
« Reply #11 on: Sun, 06 October 2013, 03:58:29 »
I thought MX Reds felt really nice, even for typing. I imagine 62g Vintage Blacks (lubed if possible) would be even nicer.
Offline PointyFox
« Reply #12 on: Sun, 06 October 2013, 03:59:52 »
I heard the opposite.  I vote for MX Clear or vintage MX Black.
Offline mauri
« Reply #13 on: Sun, 06 October 2013, 04:00:07 »
You know nothing, cherry ML is the ****
Offline dragonxx21
« Reply #14 on: Sun, 06 October 2013, 04:01:02 »
I'm pretty sure MX whites are heavier than blacks. Whites have an actuation force of 80 cN, whereas blacks have 60 cN. Unless you are talking about vintage whites, which have an actuation force of 50 cN.
I have no problem typing on Reds. I've just gotten used to the tactility, and not having it somewhat hinders me when I'm typing fast.
Keyboards Owned:
  • HHKB Pro
« Reply #15 on: Sun, 06 October 2013, 04:04:41 »
Odd, I felt that I could type even faster on reds. The lack of tactility and the light feeling of the switch meant I bottomed out on nearly every press, but I could go super fast as a result.
You could also give vintage blues a try. Very slightly different, but if you enjoy blues chances are you'll like vintage blues too. To me they feel like the actuation point is just a bit lower and the tactility is just a bit reduced.
« Last Edit: Sun, 06 October 2013, 04:08:57 by ComradeSniper »
Offline mauri
« Reply #16 on: Sun, 06 October 2013, 04:06:31 »
Shouldn't blindly worship the actuation force gods, some people find that whites require less or equal amount of force as blacks.
Offline dragonxx21
« Reply #17 on: Sun, 06 October 2013, 04:07:02 »
OP Updated with Poll
I'm unsure about what you mean by vintage blues. I've never seen anything about vintage blues, and can't find anything about it on the deskthority wiki.
Keyboards Owned:
  • HHKB Pro
« Reply #18 on: Sun, 06 October 2013, 04:11:21 »
They have a larger Cherry logo and lighter colored stem.
http://deskthority.net/photos-videos-f8/cherry-mx-old-vs-new-t139.html
In addition, if you want to try whites but don't like heavy switches you could make ergo whites (62g Korean spring will give you pretty much the same weight as Blues). They're probably my favorite switch if you can manage to get a batch where they all click the same. Just enough tactility with a subtle enough click that you won't disturb other people working around you but it still sounds satisfying to type on.
Offline dragonxx21
« Reply #19 on: Sun, 06 October 2013, 04:14:30 »
What are your thoughts on jailhouse blues.
Keyboards Owned:
  • HHKB Pro
« Reply #20 on: Sun, 06 October 2013, 04:37:48 »
They sound great and I'd really like to try some. However, I don't have anywhere near the amount of patience it takes to actually do the mod. Something relatively quiet with the sharp tactility of blues sounds like my dream switch though.
Offline dragonxx21
« Reply #21 on: Sun, 06 October 2013, 04:42:30 »
I'm personally thinking about jailhouse blues. Similar tactility to clears, with the quieter click of whites, which would be much nicer to bring outside the home. Also, you have to love the quicker actuation.
Keyboards Owned:
Offline Oobly
« Reply #22 on: Sun, 06 October 2013, 14:32:43 »
I voted Ergoclears. Specifically 62g lubed and stickered Ergoclears. Brown used to be my favourite switch until I tried some of these Ergoclears on a section of my board and over time they have ovetaken the browns as my new favourite. Good tactility and just the right amount of pressure to activate. Not t mention the activation and release points are in the same place, unlike the clicky types.
[EDIT] - forgot to mention, for a custom board you can't use Topre as some may suggest, unless you use a PCB from an existing board with the same layout since the capacitive spring / sensor bit is integrated in the PCB design.
« Last Edit: Sun, 06 October 2013, 14:54:59 by Oobly »
Buying more keycaps,
it really hacks my wallet,
but I must have them.
« Reply #23 on: Sun, 06 October 2013, 14:35:50 »
Why this totally unnecessary requirement?
Anyway, my recommendation is lubed blues with 65g (or 62g) springs to make your own whites.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #24 on: Sun, 06 October 2013, 15:00:48 »
In my opinion... best stock switch: red, best frankenswitch: light white, best exotic switch: linear clear.
Offline dragonxx21
« Reply #25 on: Sun, 06 October 2013, 15:11:54 »
It's a custom keyboard. I could use another sort of switch such as alps or matias, but as there is quite a bit of difficulty in getting other types of switches such as those, as well as key caps for those switches, I'd rather limit it to MX switches which are relatively easy to acquire and key caps are abundant.
Keyboards Owned:
Offline Linkbane
« Reply #26 on: Sun, 06 October 2013, 20:38:36 »
I think that there's been enough assisted-wanking from the Topre fanboys, so I'd like to suggest having, as a custom, an MX Blue with a slightly higher weight spring, as dorkvader says. Acclimated Reds are and have always been horrendous for typing compared to acclimated Blue boards for me, so having something in between the Green and Blue would seem like an interesting option to me.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline MKULTRA
  • telling it how it is
« Reply #27 on: Sun, 06 October 2013, 21:13:14 »
How about you try the switches yourself and figure out what you like.  So sick of these threads.
Offline Linkbane
« Reply #28 on: Sun, 06 October 2013, 21:18:19 »
How about you not be condescending and realize that some people don't have the money to buy switch testers and things like that when they could save time and money by asking the supposedly helpful community?
Offline MKULTRA
« Reply #29 on: Sun, 06 October 2013, 21:23:52 »
Each person is going to have a different taste in switch.  There are plenty of guides describing the feeling of each switch and what they are supposedly good for, however you can't know whether or not you will like them from other people's taste.
« Reply #30 on: Sun, 06 October 2013, 21:45:13 »
Kinda like saying "I like Topre, therefore you must like Topre too".
Offline dragonxx21
« Reply #31 on: Sun, 06 October 2013, 22:04:50 »
I understand perfectly what you are saying. I made this thread with the intention of simply asking the community what switch they would personally recommend, why they would recommend it, and then use my own judgement to choose a switch. I know I could buy a switch tester and try out various stock MX switches, but then I also miss out on recommendations such as ergo clears, or panda clears, or crazy korean springs.
Anyway. I'm currently thinking jailhouse blues with some korean springs, maybe 62g or something along those lines.
Keyboards Owned:
Offline MKULTRA
« Reply #32 on: Sun, 06 October 2013, 22:13:47 »
But there are literally HUNDEREDS of threads just like this.  Look through the forums and search.
Offline Tony
« Reply #33 on: Sun, 06 October 2013, 23:09:08 »
Everyone thinks he/she is different, that's why they're alike.
Every newbie make a thread with "What would you recommend?", "What should I buy?" "What switch you like most?" in every page.
Offline dragonxx21
« Reply #34 on: Sun, 06 October 2013, 23:13:46 »
Why are you posting if you have nothing to contribute to the thread. Just because you may not agree with something doesn't mean you should go out of your way to derail it.
Keyboards Owned:
Offline Tony
« Reply #35 on: Sun, 06 October 2013, 23:54:36 »
I cherish every amusement I can feel about this recurring experience. I hope that all of us are less serious about this.
By the way, I love to type posts here with the Filco brown. That's the reason I post so many replies here in this forum.
Offline xyeLz
« Reply #36 on: Mon, 07 October 2013, 11:23:06 »
I love my Topre. :) I don't remember doing any sort of typing test back in the day on my old keyboards, but nowadays I'm getting upwards of 125WPM with the Topre. I wish it could be better. :/
ReΛlforce 87U - Capacitive (45g), ReΛlforce 103UB - Capacitive (Variable)
Offline dragonxx21
« Reply #37 on: Mon, 07 October 2013, 11:24:54 »
Thanks for your contribution. I still can't use/don't want to use topre though.
Keyboards Owned:
