Author Topic: easy keyboard dust cover (pics)  (Read 9930 times)
Offline wellington1869
« on: Mon, 15 December 2008, 14:49:23 »
Picking up where this thread left off...
Until iMav knits us our geekhack-logo'ed keyboard socks, the below is a very cheap and neat way to get a "dust cover" for your keyboards while they're in storage.
Basically, stretchy "book covers" (avail from $1 to $5 on ebay, in variety of colors), works very well.  See pics below.
Book cover, front side
Book cover, back side
Looks small? looks will be deceiving.
Put one side on end of keyboard
Now streeeetch!
Perfection.
What back side looks like.
Note that you can actually stuff the cord inside it too, I left it out here to show how neatly it fits over even a Model M sized board. Should fit all sizes nicely.
Ebay is full of these for just a few bucks.  Look for "stretchy" ones that say either that they will fit 8"x10" books, or sometimes they're sold as "one size fits all". Either of those should fit a keyboard nicely.
« Last Edit: Wed, 17 June 2009, 09:01:24 by wellington1869 »
using: ms 7000/Das 3
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #1 on: Mon, 15 December 2008, 14:51:30 »
Wouldn't these put pressure on the keys? If so, I'm not sure I would like that.
Offline Chloe
  • Switch Kitten
« Reply #2 on: Mon, 15 December 2008, 14:57:58 »
How easy is it to take off?
I'd like a plastic tray like the Filco come with as part of the packaging. I wonder if you could buy a sheet of thin plastic and heat it with a hair dryer so it just molds to fit the keyboard.
« Reply #3 on: Mon, 15 December 2008, 14:59:49 »
Quote from: xsphat;14913
no pressure at all, the keys dont depress at all. Its all very light and fluffy.
« Reply #4 on: Mon, 15 December 2008, 15:02:33 »
Quote from: Chloe;14918
very easy, like putting on your socks :)  The stretchy ones really stretch very well.
They do have plastic like that, I've seen it in craft stores, they use it to make molds.
On ebay I've also seen these neat plastic crystals that you put in boiling water for a minute and then you can shape it for 10 minutes into any shape you want (put it on your keyboard and press down for a mold) and it hardens after that.
Offline itlnstln
« Reply #5 on: Mon, 15 December 2008, 15:05:13 »
Are you trying to hide the identities of the Alt, Shift, Tab, F4 and F8 keys?  Are they turning State's on the SysRq key?
« Reply #6 on: Mon, 15 December 2008, 15:10:23 »
Quote from: itlnstln;14925
Are trying to hide the identities of the Alt, Shift, Tab, F4 and F8 keys?  Are they turning State's on the SysRq key?
hahahaha! No, that velcro is so my thumbs and fingers find those keys with confidence and easily -- The two alt keys are my hotkeys in autohotkey, so is tab and capslock (which is remapped as control of course).  (on the function keys its volume and play/pause (so again I dont have to look down, just feel).
Velcro on shift key just cuz my pinky slips and I'm annoyed when it does - velcro solves 99 percent of the worlds problems.
Offline itlnstln
« Reply #7 on: Mon, 15 December 2008, 15:12:17 »
I guess duct tape solves the other 1% then.
« Reply #8 on: Mon, 15 December 2008, 15:14:02 »
Quote from: itlnstln;14931
:D precisely
Offline xsphat
  • Enlightened
« Reply #9 on: Mon, 15 December 2008, 15:14:51 »
That is funny. I thought Wellington bought a jacked up Model M off eBay.
Offline itlnstln
« Reply #10 on: Mon, 15 December 2008, 15:15:34 »
The other nice thing about the stretchy book covers is that you can see the birth certificate for applicable keyboards, so if you have mulitple, say, Model Ms, you can tell which one it is without taking off the cover.  It doesn't help, though, if you're me and both your Ms are from the same year. :(
« Reply #11 on: Mon, 15 December 2008, 15:21:30 »
Quote from: itlnstln;14935
well thats why you get different colored covers :)
Offline itlnstln
« Reply #12 on: Mon, 15 December 2008, 15:39:28 »
Quote from: wellington1869;14937
I'll be damned if I would be able to remember them based on that.  That is, if I had enough keyboards that I would be lost in my own collection.
Offline bhtooefr
    • bhtooefr.org
« Reply #13 on: Mon, 15 December 2008, 16:44:31 »
That's when you get picky about the date, or the ID number, or something.
« Reply #14 on: Mon, 15 December 2008, 16:53:42 »
Quote from: itlnstln;14938
You could always scrawl across the cover in magic marker (just tryin' to help ya out here ;) )
Offline fkeidjn
« Reply #15 on: Tue, 16 December 2008, 00:11:30 »
You can get these at OfficeMax or -Depot, Walgreens, Walmart, RiteAid, etc.  Depending on where you live, they may or may not have them in stock.
Kinesis Keypad - Filco FKBN104M/EB - Unitek space-saver - Acer 6511-TW - Apple Extended II (M3501) - Scorpius M10 - Cherry G80-1800, AT - SGI Granite - vintage Fujitsu - IBM Model M, 101 and mini - Model F, 84-key AT - Dell AT101W - Northgate 101
Offline itlnstln
« Reply #16 on: Tue, 16 December 2008, 05:54:38 »
Quote from: wellington1869;14955
I use crayons; the big husky kind.
« Reply #17 on: Wed, 17 December 2008, 23:59:03 »
Quote from: wellington1869;14922
three more kinds of moldable plastic if you want to mold your own cover (or anything else):
plastic pellets called "shapelock"
"metal clay" (looks like silver after its dried)
"magic-sculp"
