Author Topic: Question regarding G80 3000 and das3  (Read 5629 times)
Offline lam47
« on: Tue, 16 December 2008, 13:08:54 »
These are both blue cherry I know.
Would the key caps be interchangeable. Particularly the space bar and other keys with metal bars.
Also has anyone got a G80 3000 they wouldn't mind looking under the space bar to see if the switch connects in the middle of the space bar or off to the left like a G81.
Thanks guys.
I love you all.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline bhtooefr
    • bhtooefr.org
« Reply #1 on: Tue, 16 December 2008, 13:12:56 »
Although the setup of the metal bar is different from stock, here's a pic from lowpoly's spacesaver, which is based on a cutdown G80-3000:
Offline lowpoly
« Reply #2 on: Tue, 16 December 2008, 13:25:10 »
Quote from: lam47;15019
Current G80-3000LSCEU/2:
Offline lam47
« Reply #3 on: Tue, 16 December 2008, 14:56:31 »
Thanks guys. the space bar is different to the das damn it.
Das has the switch in the centre.
Anyone got any clever ideas to mod one for a das?
Offline wellington1869
« Reply #4 on: Tue, 16 December 2008, 16:24:46 »
Quote from: lam47;15031
you mean besides soldering iron and drill?  ;)
using: ms 7000/Das 3
Offline itlnstln
« Reply #5 on: Tue, 16 December 2008, 16:28:09 »
Quote from: wellington1869;15037
I thought you said that velcro could solve these types of problems. :confused:
« Reply #6 on: Tue, 16 December 2008, 17:24:50 »
Quote from: itlnstln;15040
:D It would if cherry installed switches on the pcb with velcro. And I'd highly recommend that ;)
Actually I dont understand why switches have to be soldered down at all, why not put each in a socket? So much easier to swap out bum switches or switch type. There's an idea for lowpoly's new board. His pcb should come with sockets into which the switches go.
Offline lam47
« Reply #7 on: Tue, 16 December 2008, 17:28:00 »
I was thinking perhaps a mod to the space bar more sensible :)
Offline bhtooefr
    • bhtooefr.org
« Reply #8 on: Tue, 16 December 2008, 17:37:08 »
Because sockets are less reliable than soldered components, and they cost money.
Offline Chloe
  • Switch Kitten
« Reply #9 on: Tue, 16 December 2008, 20:55:37 »
I would do it this way, and use some copper wire across the switch pins to reinforce the PCB mounting since there are no pads.
Offline lam47
« Reply #10 on: Wed, 17 December 2008, 05:04:36 »
To make a square hole in the steel wont be simple though.
My idea was to cut the plastic cross section from the underside of one key and bond it to the centre of the space bar.
Seems like a lot less hassle.
Offline lam47
« Reply #11 on: Wed, 17 December 2008, 05:08:56 »
Got an email from Cherry this morning.
I asked if they could sell me some keys separately, they said sorry but no.
However they offered to send some for free!
How cool of them is that.
All I need to do is mod the space bar and I should be good to go!
Offline Chloe
  • Switch Kitten
« Reply #12 on: Wed, 17 December 2008, 05:19:03 »
Quote from: lam47;15115
Are the switches plate mounted in the DAS?
Offline lam47
« Reply #13 on: Wed, 17 December 2008, 05:34:06 »
Yes they are, Through the steel plate and into the PCB.
It would be quite tricky and messy (for me) to cut the correct size square hole for the switch. I like working with plastics a lot better :)
Offline Chloe
  • Switch Kitten
« Reply #14 on: Wed, 17 December 2008, 05:40:00 »
That's a pain. I would have preferred drilling and soldering, but your idea about bonding the plastic sounds like it will work. Cutting metal scares me.
Offline lam47
« Reply #15 on: Wed, 17 December 2008, 05:53:31 »
Aluminium I'm Ok with but steel is such hard work.
Fingers crossed this works :)
Offline lam47
« Reply #16 on: Thu, 18 December 2008, 12:21:07 »
The nice people at Cherry sent me a couple of keys today.
They are shallow compared to the das keys so sit slightly lower than the others.
I did contact the Das keyboard official site who said they are looking into getting replacement key sets in the new year.
