Author Topic: [ebay] Unicomp Buckling Spring with Trackball USED $55  (Read 2418 times)
Offline morpheus
Offline MTManiac
Re: [ebay] Unicomp Buckling Spring with Trackball USED $55
« Reply #1 on: Mon, 07 October 2013, 15:49:57 »
that's going to go fast
anyone know the dpi options on the trackball?
« Reply #2 on: Mon, 07 October 2013, 16:04:48 »
8200 cpi if you have this:
http://geekhack.org/index.php?topic=44411.0
The actual encoder it's using likely is optomechnical, and cpi is not as useful a measure on a trackball as counts per rotation or counts per degree.
Offline elttaboi
« Reply #3 on: Tue, 08 October 2013, 01:40:42 »
Would this be equal in build quality as a Model M of the same year?
« Reply #4 on: Tue, 08 October 2013, 10:35:43 »
Yes.
But that's because it IS a "model M of the same year." You are asking if a Unicomp will have the same build quality as a Unicomp. You can deduce that they will (by definition).
The plate will be thinner than a model M of the late 1980's, the case is likely slightly different plastic. See all the articles meticulously cataloging the differences in the Model M keyboard throughout time.
Offline JWK
« Reply #5 on: Thu, 10 October 2013, 13:14:57 »
  • Live long and prosper
« Reply #6 on: Thu, 10 October 2013, 13:47:05 »
^This. I made that mistake once.
tp thread is tp thread
