Author Topic: USB to PS2 Converter  (Read 1454 times)
Offline Kon
« on: Mon, 07 October 2013, 17:15:25 »
I was pointed to this site because i am searching for one of these for a friend who built a new system and now cant use his SS 7G, person who referred me here said you guys would know whats what. i have tried searching quickly but there is way to many threads to sift through to find the what im looking for, i will continue to look but hopefully someone will help me out
Re: USB to PS2 Converter
« Reply #1 on: Mon, 07 October 2013, 17:18:37 »
Look at #2 here. In the future, feel free to ask questions in Simple Questions, Simple Answers so you don't need to create a new thread just to ask a question :D.
And welcome to Geekhack!
Edit: Er, if you're looking for a USB to PS/2 adapter and not a PS/2 to USB adapter, I'm sure Amazon has some. Might have had some dyslexia with my first post. Sorry!
« Last Edit: Mon, 07 October 2013, 17:26:21 by CPTBadAss »
Offline Kon
« Reply #2 on: Mon, 07 October 2013, 17:27:44 »
Thanks ill give that adapter a go, and i did search the first 2 pages of that thread saw nothing on PS2
« Reply #3 on: Mon, 07 October 2013, 17:29:28 »
Easier just to ask in that thread next time is all I meant ^__^
Offline Kon
« Reply #4 on: Mon, 07 October 2013, 17:33:58 »
he has a Sabertooth z87 it has no ps2 port and his Keyboard connects via PS2
« Reply #5 on: Mon, 07 October 2013, 17:45:12 »
so you are converting a ps2 keyboard to plug into a usb motherboard, right?
The "best" one is likely the teensy running soarer's code. It's a diy job, and expensive ($25 or so) but fully programmable and supporting NKRO over usb.
http://geekhack.org/index.php?topic=17458.0
the better commercial / premade ones are the ID innovations multimode usb adapter. I have several and they don't "reset" like many others do. they also support 6KRO, so you can use them for gaming.
http://geekhack.org/index.php?topic=48030.0 ($12)
lots of people like the "blue cube" adapter. I haven't used it, but I can't see how it'd be better than the above.
oh, and Welcome to Geekhack!
Offline Kon
« Reply #6 on: Mon, 07 October 2013, 17:49:37 »
i can assure you hes not into technical stuff i mean he didnt even think about whether his new mobo had a PS2 Port , just going to get him this for christmas. i think i got it sorted now , hopefully this all works
