Author Topic: Blackwidow water spill now spacebar a little weird.  (Read 1208 times)
Offline ogamerdg
« on: Mon, 07 October 2013, 17:17:55 »
So I spilled water on my Blackwidow keyboard and some keys were being weird and spacebar wasn’t working at all. So I used a hair dryer and left it upside down. After a while I plugged it in and everything worked except the spacebar. The spacebar won’t do anything when I hold it down and only spaces if the key is all the way up. So can someone tell me why this is happening when the key is working and also the best way to fix/clean the spacebar? Thanks
Offline C5Allroad
  • Formerly HUNTERANGEL121
Re: Blackwidow water spill now spacebar a little weird.
« Reply #1 on: Mon, 07 October 2013, 19:05:51 »
I don't know if anyone else would agree or if it's a good solution( I'm going with what I learned in biology...) regular water has minerals so eventually it would erode. Take apart the board and rinse with distiller water and let it dry for a few days.
« Reply #2 on: Mon, 07 October 2013, 19:36:22 »
You might be up for a switch replacement.
