Author Topic: Teensy Question - Mini-B USB Extension/Adapter  (Read 3208 times)
Offline Tarzan
  • formerly known as Greystoke
« on: Wed, 09 October 2013, 08:57:45 »
Not sure where to ask this question, but it is for a keyboard build, so...
For people who have used a Teensy to modify a terminal keyboard (or lowpoly wired keyboard...) to use a detachable USB cable, which adapter have you used?
I purchased one of the Mini-B to Standard-B Panel Mount Adapter from PJRC, but I'm interested in using a Mini-B or Micro-B instead.  Has anyone ordered these, and if so, where did you source them?
I've found several links, like the one below, but prices are all over the map.  Any recommendations?
http://www.usbfirewire.com/usb_cables_mini-b_extensions_extension_adapters_86.html
Offline Tarzan
Re: Teensy Question - Mini-B USB Extension/Adapter
« Reply #2 on: Wed, 09 October 2013, 09:13:45 »
Would something like this work?
http://www.ebay.com/itm/Mini-USB-B-5pin-Male-to-Female-extension-adapter-cable-/270930517122
That would probably work, but I was hoping for a panel mount solution of some sort, for a clean appearance.  Maybe I could Dremel an opening in the case and glue the end of the cable flush with the exterior...
Failing that I guess I could just get a Mini-B to Standard-A cable, and make them USB keyboards - with fixed cables.  That's probably the cheapest solution, but I like all the custom sleeved cable options!
« Reply #3 on: Wed, 09 October 2013, 09:15:56 »
Doh I need to read better, I was thinking about you wanting panel mounting.
What about getting one of the small breakout boards like this and glue it in or something?
https://www.sparkfun.com/products/9966
Offline Tarzan
« Reply #4 on: Wed, 09 October 2013, 09:20:26 »
I'm looking for something more like the one below, but Mini-A/Micro-A on the panel mount end:
38317-0
Offline esoomenona
  • Gnillort?
Offline Tarzan
« Reply #7 on: Wed, 09 October 2013, 10:03:20 »
http://www.alliedelec.com/search/productdetail.aspx?SKU=70144951
I have a Filco cable with one of these connectors on it.
That's a nice-looking connector!  I just find it appalling that the cable connector is as expensive as the entire Teensy.   :eek:
Offline Hellmark
« Reply #8 on: Wed, 09 October 2013, 10:33:22 »
Amphenol always has been proud of their stuff.
