Author Topic: Hi  (Read 3020 times)
Offline elllit
Hi
« on: Wed, 09 October 2013, 10:15:49 »
Hi!
Last time i decided to buy another keyboard because the last was kinda worn out I wanted to go mechanical. But i decided against it. That may have been was a mistake. I still don't feel comfortable with it, even after several months.
So I went out into the internet to search for a decent mechanical keyboard. This time I also wanted to go ergonomic, because I think it might help me find a more comfy pose at the desk. :) Looking around the internet I found the threads about the ergodox in this forum. I instantly was intrigued about the design, the configurability and especially the open source nature of the project.
After some more days of browsing through threads I found AcidFire's take on modifying the ergodox and think splitting the thumb cluster from the other part is a good way to facilitate mods.
I'm rambling...
Hi, from Germany.
--- elllit
  • Live long and prosper
Re: Hi
« Reply #1 on: Wed, 09 October 2013, 10:20:27 »
tp thread is tp thread
Offline elllit
Re: Hi
« Reply #2 on: Thu, 10 October 2013, 15:07:44 »
A small follow-up.
I ordered a G80-3000LQCEU-0, because it's kinda "cheap" (~60 Euros) and supposed to have MX Clear keys which I wanted to try first.
If the board sucks, I have a source to salvage some keys from, right? ;)
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
Re: Hi
« Reply #3 on: Thu, 10 October 2013, 15:27:56 »
Welcome to GH!
Keep in mind that this specific G80 only has lasered keycaps... so not the best board to salvage keycaps from.
Offline Pacifist
  • on hiatus
Re: Hi
« Reply #4 on: Thu, 10 October 2013, 15:28:00 »
Where did you get the g80?
Offline elllit
Re: Hi
« Reply #5 on: Thu, 10 October 2013, 15:34:56 »
@snoopy:
Can you elaborate on that point?
@Pacifist:
amazon.de
Offline snoopy
  • The Flying Ace
Re: Hi
« Reply #6 on: Thu, 10 October 2013, 17:12:13 »
Try to search a bit around. But in general, there are lasered, doubleshot and dye-sub keycaps. And most people prefer doubleshot or dyesub. You should find a lot of information about that with the forum search function.
You can see that on the code of your G80... For example the 'L' stands for lasered....
Offline elllit
Re: Hi
« Reply #7 on: Fri, 11 October 2013, 04:41:31 »
Thanks for the hint with the "L".
Actually, I had the MX Clears in mind when I mentioned salvaging parts, not the caps. :)
But I read up a little on the different types of lasered (engraving, etching), pad-printed, double-shot, and dye-sublimated caps. Thanks for this hint as well. And I understand why people prefer the last two ones most.
Offline pexon
  • El Jefe of Sleeving
    • Pexon PCs
Re: Hi
« Reply #8 on: Fri, 11 October 2013, 04:41:57 »
Welcome aboard dude!  :thumb:
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
Re: Hi
« Reply #9 on: Fri, 11 October 2013, 12:41:36 »
WELCOME TO GEEKHACK!
Offline elllit
Re: Hi
« Reply #10 on: Fri, 01 November 2013, 15:13:34 »
So, I have been hacking away on my first mechanical keyboard for about 2 weeks. It definetly is a different experience! My co-workers are not that annoyed... one mentioned "Now we can here you work in the hallway". So, good that I chose the MX Clears and nothing really clicky, eh? ;)
Besides the obvious change from rubber domes I also opted for a different keyboard layout: english instead of german. I took quite a while to get into that, longer than i thought. And I still mix up 'z' and 'y'. :)
Now to the part where I could use your knowledge: It seems that typing along takes more of a toll than before - my forearms and fingers feel more tense after work.
What do you think?
Is it because I am still not completely used to the new layout?
Is it because I am not used to write on a mechanical keyboard? (I feel like I am hitting the keys too hard...)
Is it because the keyboard itself is not very ergonomic? (I at least had pretty flat keyboards or a plam rest on my keyboards, nothing 'real' ergo tho)
Thanks,
-- elllit
