Author Topic: (Help) Looking for aluminum pink TKL case w/ thick PBT pink caps (87)  (Read 3248 times)
Offline libo720
Hi, i plan on making an all pink Filco. However, i cannot find these 2 items anywhere, someone suggested me to anodize the case myself but i don't want to do that unless i absolutely have to. Also apparently pink thick PBT keycaps don't exist : (
« Last Edit: Wed, 09 October 2013, 17:10:18 by libo720 »
Realforce 87U Tenkeyless 55g
Offline Photoelectric
Re: (Help) Looking for aluminum pink TKL case w/ thick PBT pink caps (87)
« Reply #1 on: Wed, 09 October 2013, 17:13:00 »
There is no pink aluminum case for a Filco, so you will have to get a silver one and get it anodized yourself, as others suggested.  There's a pink limited edition plastic Filco case, but it comes with the keyboard (and is in very limited supply now) and you're looking for aluminum.
Pink thick double-shot PBT caps (well, white + pink):
http://geekhack.org/index.php?topic=48932.0
Offline libo720
« Reply #2 on: Wed, 09 October 2013, 17:26:59 »
So where can i find the plastic pink filco? I guess i'll just make do with that and some pink ABS caps because it looks like thick complete pink PBT caps do not exist either.
« Reply #3 on: Wed, 09 October 2013, 17:30:51 »
Well... it appears it finally sold out at Amazon.com.  Not sure now :(  Could try the classifieds or keep an eye out for it.  Here's what mine looks like
Offline libo720
« Reply #4 on: Wed, 09 October 2013, 17:32:01 »
Is that case plastic or aluminum? Kind of hard to tell.
« Reply #5 on: Wed, 09 October 2013, 17:32:19 »
As I said, it's plastic :)
« Reply #6 on: Wed, 09 October 2013, 17:33:38 »
I dyed my own caps to make thick pink pbt. No one knows I did it huehueuhe
Offline libo720
« Reply #7 on: Wed, 09 October 2013, 17:35:28 »
Lets say i decide to dye the caps and anodize the cases myself, how would i go to do that? I have zero clue.
« Reply #8 on: Wed, 09 October 2013, 17:36:04 »
anodizing the case you give it to a factory, dyeing pbt just get a blank white set from imsto or something, boil some water, pour in dye, stir em up.
« Reply #9 on: Wed, 09 October 2013, 17:37:53 »
You can get this case in silver:
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=212
And prior to that, google anodizing service in your area and get some quotes to see if it's worth it for you.
Otherwise, you can always paint your plastic case pink.
http://geekhack.org/index.php?topic=44191.0
« Reply #10 on: Wed, 09 October 2013, 17:41:32 »
could theoretically paint metal too ^_^
Offline libo720
« Reply #11 on: Wed, 09 October 2013, 17:43:55 »
Thanks for the helpful information guys!
