Author Topic: Compaq G80-1838HPU/01  (Read 2783 times)
Offline chocobunny
« on: Thu, 10 October 2013, 13:56:06 »
Looks brand new, ending soon!
http://www.ebay.com/itm/271293358789
Was hoping to snag it for myself but it'll probably go far beyond my budget. :(
Re: Compaq G80-1838HPU/01
« Reply #1 on: Thu, 10 October 2013, 20:22:35 »
I take it went for beyond your budget ($102) ?
anyone here get it?
Offline dante
« Reply #2 on: Thu, 10 October 2013, 22:11:01 »
I would have fought for it if it were black/pom.
Offline esoomenona
  • Gnillort?
« Reply #3 on: Thu, 10 October 2013, 23:29:36 »
I was planning to bid on it but forgot while browsing the internet and was half a minute too late...
Offline sherryton
  • Kībōdo
    • Originative
« Reply #4 on: Thu, 10 October 2013, 23:52:11 »
SAME HERE, NO JOKE
I was on this page for 6 hours prior to the end too.  I had it on the whole time.
Offline do_Og@n
« Reply #5 on: Fri, 11 October 2013, 15:50:39 »
I bid on it but as soon as it hit over $50 I was out. I'm sure I'll find one for cheap one day.
Offline ebacho
« Reply #6 on: Fri, 11 October 2013, 19:26:14 »
Problem for me is the non-standard top two rows, which makes it worth less if you're bidding on it partly for the keys.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Fri, 11 October 2013, 20:08:08 »
Yeh it only has B,C,D row profiles. It's not that annoying to type on though really. I guess they did it to keep it low enough to slide inside a 1u rackspace.
