Author Topic: Need Help with a Topre Dome Swap  (Read 1876 times)
Offline SNF
« on: Thu, 10 October 2013, 21:17:08 »
So I swapped in some new domes, everything is fine except the enter and backspace feels stiff and feels like sh*t compared to other keys.
Anyone ever ran into this and know a fix?
thx.
**EDIT**
Ok so evidently, for the stabilizer keys, make sure not to cut too much off the rubberdome, make sure there is an even square around the switch if that makes sense.
Something to take note of for anyone in the future that has to make custom cuts for topre rubberdomes  :thumb:
Also, do not over torque the screws on the pcb or the screw head will break  :(
« Last Edit: Thu, 10 October 2013, 23:17:28 by SNF »
Offline MKULTRA
  • telling it how it is
Re: Need Help with a Topre Dome Swap
« Reply #1 on: Thu, 10 October 2013, 21:29:39 »
thx.
Are you sure they're installed properly?
Offline SNF
« Reply #2 on: Thu, 10 October 2013, 23:14:05 »
thx.
Problem fixed, see EDIT
Offline dreamingftw
« Reply #3 on: Thu, 10 October 2013, 23:34:05 »
What kind of swapping did you do?
Offline SNF
« Reply #4 on: Fri, 11 October 2013, 00:39:51 »
30g into a 87u variable :3
Waiting for my caps to come home tomorrow to try them out  :cool:
