Author Topic: Does anyone know where I can buy keycaps in the UK?  (Read 1970 times)
Offline Ewanhen
« on: Fri, 11 October 2013, 11:29:16 »
Does anyone know any websites that I can buy keycaps from in the UK?
Help would be much appreciated!
Keyboard is a Filco Majestouch 2 TKL with browns
Re: Does anyone know where I can buy keycaps in the UK?
« Reply #1 on: Fri, 11 October 2013, 11:30:31 »
There aren't really any full sets you can buy in the UK.. at least not nice ones. Is the keyboard an ANSI or ISO layout?
Offline Ewanhen
« Reply #2 on: Fri, 11 October 2013, 11:33:59 »
Ansi
Offline McWilloughby
« Reply #3 on: Fri, 11 October 2013, 11:37:08 »
I've bought stuff from WASDkeyboards (their shipping isn't too bad but there is much better stuff out there), feng (a geekhack member who sells stuff on ebay, very quick shipping) and QWERkeys which is the UK.
« Reply #4 on: Fri, 11 October 2013, 11:37:33 »
Ansi
Oh that's good. There are plenty of nice keycaps you can get for that, however you just can't get very many nice full sets from within the UK. I would recommend a set from originativeco.com (site is currently down). They have very nice sets made by GMK & BSP (generally considered the nicest MX keycaps available anywhere).
Offline Ewanhen
« Reply #5 on: Fri, 11 October 2013, 11:44:04 »
Thanks
« Reply #6 on: Fri, 11 October 2013, 22:39:43 »
This will get you started: http://www.qwerkeys.co.uk/shop/
Here also: http://www.keyboardco.com/
Offline Aliwia
  • WTB Cuprubber
« Reply #7 on: Sun, 13 October 2013, 15:46:35 »
MAX keyboard sets have OEM packaging which is cheap to the uk.
