Author Topic: Filco, are they worth looking into?  (Read 27914 times)
Offline Fragil1ty
  • Abre los ojos.
« on: Fri, 11 October 2013, 15:39:24 »
Hey guys, I've decided to stray away from my Keycool and look into other boards, more specifically the "Filco Ninja Majestouch-2" Obviously I want the Tenkeyless model, but one thing is, I'm not 100% sold on them.
They look 'okay', nothing spectacular in my opinion, maybe your opinion may differ but yeah.
The only I don't like really is where the scroll lock and caps lock lights are positioned.
So, just a few questions really.
If I order from UK manufactuerers, it'll cost me £114, so:
1. Are they worth the money, do they have good construction etc?
2. What are they like to type on, what keycaps do they use? PBT/POM etc?
3. Would you recommend one to a friend or whatever?
If not, what is a good keyboard similar to this or the Keycool 84 80% type keyboards?
Thanks.
你搞砸了
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: Filco, are they worth looking into?
« Reply #1 on: Fri, 11 October 2013, 15:42:07 »
Filcos are great keyboards but you can grab a cm storm for cheaper and doesn't lack quality.
If you go filco or storm you won'r regret it. Filcos/cm storm has ABS keycaps.
-Enzo Ferrari
Offline Fragil1ty
  • Abre los ojos.
« Reply #2 on: Fri, 11 October 2013, 15:46:20 »
That's the only thing drawing me back at the moment, for a tenkeyless board  £114-120 seems a little steep.
你搞砸了
« Reply #3 on: Fri, 11 October 2013, 15:47:03 »
My filco was good. The price is steep though.
Offline AuRinBei
« Reply #4 on: Fri, 11 October 2013, 15:53:25 »
I don't have a Filco, so I don't know this for sure, but don't the caps have a problem with their UV protective coating rubbing off easily?
87u || Poker 2
Offline JPG
  • Model F is my new passion!
« Reply #5 on: Fri, 11 October 2013, 15:57:10 »
I have 2 filco's. Hard to tell if all the price is justified, but they are very good quality and you also have a lot of choice for switches/layout. Maybe a lil overpriced, but definitely very good.
Offline saturnotaku
« Reply #6 on: Fri, 11 October 2013, 16:00:16 »
A CM Storm Quickfire Rapid is just as good as a Filco and costs roughly £70-80, sometimes less if you catch a good sale. I bought mine for USD$65. This is if you want a keyboard with a standard tenkeyless layout.
For 80% and smaller models, there's the TG3 Electronics BL82 (pics here), the KBT Race, and Leopold FC660M (MX switch) and FC660C (Topre switch).
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #7 on: Fri, 11 October 2013, 16:21:46 »
Filco is ok and all, but nothing special. They used to be premier MX keyboards, but now days many other manufactures have caught up in quality as far as I am concerned and offer more features, nicer aesthetics in some cases while being less expensive.
« Reply #8 on: Fri, 11 October 2013, 16:36:33 »
I own 3 filcos. I love everything about them.
Get one.
Offline Tony
« Reply #9 on: Fri, 11 October 2013, 16:39:50 »
I have two Filcos. Filco are of the best quality and the price is high too.
If you can afford it, then definitely go for it.
If you are tight budget, grab a CMstorm Quickfire Rapid.
Sooner or later you will buy a Filco anyway.
Buying it the first time saves time, which cannot be bought.
Offline esoomenona
  • Gnillort?
« Reply #10 on: Fri, 11 October 2013, 16:44:33 »
I believe we call that employment.
Offline Fragil1ty
  • Abre los ojos.
« Reply #11 on: Fri, 11 October 2013, 17:40:50 »
Get one.
I am really tempted I must admit.
Don't really like the QFR font to be honest, looks kind of ugly that's why I was more towards the filco to be honest.
你搞砸了
« Reply #12 on: Fri, 11 October 2013, 17:41:23 »
They look almost identical though..
Offline Danule
« Reply #13 on: Fri, 11 October 2013, 17:53:10 »
Best mx board ive tried was a filco. I love their simple classy style.
45g Brown Brown Blue
Offline Tony
« Reply #14 on: Fri, 11 October 2013, 18:20:16 »
I touch type, so I don't look at the keycap often, yet I see that CM QFR looks weird.
For blind touch typing experience, QFR is very much similar to a Filco and QFR price is much cheaper.
For overall aesthetic and feel, Filco keyboard has the highest ratings around here. In a month you will soon forget the price difference you have to pay for it.
Anyway, your fingers deserve the best keyboard, right?
Offline calavera
« Reply #15 on: Fri, 11 October 2013, 19:10:51 »
I was gonna recommend WASD v2 keyboards but it seems they're way out of your price range.
Offline terran5992
  • One With The Cup Rubber
« Reply #16 on: Fri, 11 October 2013, 19:27:57 »
How about the code keyboards?
Offline Pacifist
  • on hiatus
« Reply #17 on: Fri, 11 October 2013, 19:36:17 »
Isn't the keycool 84 75%?
Offline EpiRock
« Reply #18 on: Fri, 11 October 2013, 19:38:49 »
I do own a Filco Ninja with browns. I've tried comparing the Filco with QFR side by side. They look basically the same besides the fonts, cable and LEDs. Not surprised since they're made by the same OEM. However, when I started typing on them, they do sound and feel quite different. I know one of the reasons might be the cause of different batches of cherry switches, not the keyboards themselves. So I tried comparing with another QFR that I bought my friend. I compared them with stock ABS keycaps and then with PBT keycaps. I can say that the Filco is indeed better imo, it sounds and feels better. Even my friend who uses the QFR say the Filco feels better after trying it. However, it is not 2x better than the QFR so you have to decide if the premium price of the Filco justifies or not. IMO Filco is not worth the price, but I'd still buy one. ;D
Offline Emospence
« Reply #19 on: Fri, 11 October 2013, 21:59:20 »
They're the board to get when it comes to Cherry switches ;)
(If price is not an issue)
Keyboards: Topre Realforce 87UW 55g x 2
Mice: Zowie EC1 eVo CL x 2
Mousepads: Artisan Hien VE x 2, Razer Mantis Speed
Offline Linkbane
« Reply #20 on: Fri, 11 October 2013, 22:11:39 »
I would quote everyone, but it would be too great of a block. Filco has very, very high quality standards but I think that the price is completely unjustified, considering that the same company, Costar, makes Cooler Master as well as Filco.
I mean, the quality of the board, unless horrendously bad, isn't going to alter your typing experience. That's undoubtedly hype and false claims; a cherry is a cherry is a cherry.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
QQ
« Reply #21 on: Fri, 11 October 2013, 22:14:49 »
Honestly I know that QFR's and Filco's are from the same OEM but I'd tend to agree with Epirock, I definitely think the Filco is better quality. Don't know if they have higher quality standards but somehow the Filco just feels a lot nice to type on.
« Reply #22 on: Fri, 11 October 2013, 22:49:49 »
Get one.
Filco is a good keyboard.  QFR is similar, but many, like you, do not like the font.
What a lot of people (me included) do is get QFR and replacement keycaps for less than the price of a Filco.
Offline dante
« Reply #23 on: Fri, 11 October 2013, 22:58:33 »
Does anyone know why Keyboard Co. is unable to stock MX Brown Filco's 87/104 on Amazon?  NCIX US doesn't either but NCIX Canada does.
It's like someone bought the rights to selling the Filco Brown 87/104 in the US but they aren't doing anything with it.
Offline Lycoth
« Reply #24 on: Sat, 12 October 2013, 06:41:07 »
Filco was my first high quality board after joining GH after recommendations. I am also from the UK so I paid about the same, and to be honest I never regretted it. It was an amazing keyboard with a great feel, good quality, very sturdy, I loved the look. Anybody who used my keyboard, whether they were gamers or office staff would comment on exactly how nice it felt to type on (I had MX Browns).
I did end up selling it simply because it got to the point where I wanted a backlit board (For certain modifiers and the such that I couldn't always hit without looking), and something slightly more aesthetically pleasing as I had got bored of the standard look, So I replaced it with a Ducky, selling to a friend of mine, who had never used a mechanical keyboard. He says he never wants to replace it.
I hope that answers some of your concerns about whether it's worth the asking price.
Offline Austin Powers
« Reply #25 on: Sat, 12 October 2013, 07:19:15 »
Go for filco, mostly every set of common keycaps will fit on them. IMO, the non ninja version is cheaper compared the ninja version. It comes with ABS though. Here's my suggestion, go for the non ninja version and change those keycaps into PBT or POM.
Offline ZeodoHokill
« Reply #26 on: Sat, 12 October 2013, 07:42:49 »
I can find some shop locally and the shop keeper usually allow us to "play" with his product, and sometime we can compare the product from Filco with other provider, I think that Filco product is better in quality in general, their key response feel solid, and the key alignment is better also (in other provider you may find the key not quite align since poor switch bonding alignment). Like now I am currently using Filco Majestic MINI Air to type this message, the only difficulty I still not very get used to 60% keyboard.
« Last Edit: Sat, 12 October 2013, 07:44:42 by ZeodoHokill »
Offline Grim Fandango
« Reply #27 on: Sat, 12 October 2013, 08:25:31 »
Yes, they are worth it, and they are known for being solidly built keyboards. However, there are some things to take into account. One is that they are sold from the UK. This makes it more attractive if you live in Europe, and less attractive if you live in the US because of shipping and customs charges. The other thing is that you can get something very close for a lot less. I have 2 Filcos but have also used the CM Quickfire rapid and it came awfully close while costing almost half. Many of the characteristics of these keyboards are the same, like the dimensions and the stabilizers.
It is not possible for me to describe the way they subtly differ from another keyboard. This is one of those things you will just have to try. The stock keycaps they use are kind of crap. They are ABS , which is fine, though many people now prefer PBT etc., but they are also pad printed. Now I do not hate pad printing as much as some. My experience has always been that the printing does not fade quickly or easily. However, the pad printing on the Filco keycaps is kind of ugly and inconsistent (different shades and not perfectly printed). Most people here would swap out the keycaps.
I would recommend them. But there are a few things I would take into consideration before I would. To be just really honest, if that friend is not a touch typist and does not type a lot, I would feel like he should not even bother. That is just a personal thing though. I do not think I could enjoy mechanical keyboards the way I do now if I did not type properly. A lot of the feel and experience is lost if you do not. I would also look at his budget. If he had trouble spending that much money on a keyboard I would probably tell him to just go with the Quickfire rapid.
Offline Belfong
« Reply #28 on: Sat, 12 October 2013, 08:49:13 »
Having not used a Filco before, I'm curious on two counts. Many here says it's expensive. How much is it anyway? US$150?
And if it US$150, that made Filco the same as WASD and Matias. So how does Filco compares to these two in terms of quality?
« Reply #29 on: Sat, 12 October 2013, 09:32:14 »
It's something like $150 yeah. I got mine in Japan for cheap, so I wouldn't know.
It's certainly higher quality than WASD or Matias (or CM for that matter, that's Costar too). I've revived my miniLA twice from juice spills.
Offline Belfong
« Reply #30 on: Sat, 12 October 2013, 09:51:31 »
And yet, in this thread everybody thinks that Filco is overpriced. If that is the case WASD and Matias would be even worse, if as you said, their quality is not as good as Filco's. Sometimes, these stuff are so subjective, it's really hard to place - what does quality means, right? In some threads, I see people complaining that their Filco has keys dead on arrival.
So, OP, my advise, just buy what you think you liked in terms of branding.
Offline Danule
« Reply #31 on: Sat, 12 October 2013, 10:01:07 »
I have 2 and have had no issues,  I have taken 1 apart because i spilled water inside.  The soldering and PCB are high quality, maybe not as nice as a realforce, but very nice none the less :)
Offline Tony
« Reply #32 on: Sat, 12 October 2013, 10:26:23 »
Filco is a luxurious keyboard. It is highly priced, but if you can afford it, then definitely go for it, like a Porsche or Rolls Royce car which is also a luxurious item.
You don't buy it because it is cheap and has the best p/p factor, but because of the luxuries it brings to you. It massages your fingers and your ego at the same time. Your delicate fingers certainly deserve the best keyboards the world can offer.
Looking at another angle: Part of a Filco keyboard's price is the brand price. In my own country you can sell a second hand Filco much faster than any other brands.
« Last Edit: Sat, 12 October 2013, 11:47:58 by Tony »
Offline Danule
« Reply #33 on: Sat, 12 October 2013, 10:54:13 »
yeah the resale value of filso, hhk, and realforces are very good.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #34 on: Sat, 12 October 2013, 11:43:32 »
Yeah I'll admit the QFR font do look weird.
BUT if you get QFR Stealth I find I actually like that font in that one.  Maybe because it's smaller and less noticeable so it's not too bad.
So I'd actually recommend you get that one instead even though I do own a Filco.  :P
Offline saturnotaku
« Reply #35 on: Sat, 12 October 2013, 12:52:12 »
A Filco is, at best, an Acura TL to the Honda Accord that is a CM Storm. There are differences between them but under the skin they are fundamentally similar.
Offline Dreamre
    • kbdlife
« Reply #36 on: Sat, 12 October 2013, 15:45:08 »
I agree with you, however I'd compare it with an Acura TSX to a Honda Accord.
« Reply #37 on: Sat, 12 October 2013, 17:02:24 »
Or just replace the keycaps.  I did :)
Currently my QFR has Miami on it.
Offline Andrew3000
« Reply #38 on: Sun, 13 October 2013, 06:19:44 »
Filcos are priced higher than average for a reason. A good keyboard is never a bunch of parts and electronic components just thrown in and soldered together, it's more about design and thoughtfull selection, deep professional understanding of its possible uses and limitations plus quality control.  It's what sets apart a brand and noname assembled from basically the same components. While there are other manufacturers making decent boards that are more affordable or feature-rich, every Filco I have tried was absolutely worth every dime of its price.
Offline skuko
« Reply #39 on: Sun, 13 October 2013, 06:39:20 »
i have 3 filcos, 1 of them is being RMAd now, one blue switch didn't click out of the box. other than that, they are flawless.
the only thing i'd love to have on them is to have plate cutouts for solderless switch swapping :)
Offline amasokin
  • KBD Lunatic
« Reply #40 on: Sun, 13 October 2013, 06:47:05 »
I think the Filcos feel better than any of the other Cherry keyboard I've ever tried. They're sturdier, better polished, and the typing feeling is just amazing. Typing on Blues on a Filco is not the same as typing on Blues on a Ducky (which is also plate mounted) for example. Not at all. And not just because of the Cherry vs Costar stabilizers.
Keep in mind though, it's the only Costar-made keyboard I've ever tried, never had a QFR. Considering the price difference, it may be worth looking into.
As someone said earlier in this thread though, "collection" and resale value of the Filco are much higher.
Keycaps quality/font is not really an argument, considering you'll probably be changing them quite fast :p
Offline ch_123
« Reply #41 on: Sun, 13 October 2013, 06:58:25 »
I've owned both a WASD V2 and a Filco, and I prefer the WASD. There's some nice things that the WASD has over the Filco, such as lasered keycaps (but probably irrelevant if you end up buying third party keycaps) and a detachable cable (this is more an issue of preference). Aside from that, they are quite similar, and my preference for the WASD is largely to do with the customization and other value-added services they provide compared with other Cherry keyboard vendors.
Then again, I'm more of an IBM guy, so they all are inferior to my SSK in one way or another, except perhaps noise :D
« Last Edit: Sun, 13 October 2013, 07:03:26 by ch_123 »
Offline Nakapfao
« Reply #42 on: Mon, 14 October 2013, 16:03:48 »
I agree. Got my CM Storm for about 70 bucks, and as it was coming in the mail I kinda regretted it because I thought I should've gone with something higher quality. Now that the board's here though, I've got no qualms apart from the caps, and if I replace them for about 40 bucks I'm still spending less than a lot of people :D
Offline archer
« Reply #43 on: Wed, 16 October 2013, 11:59:33 »
I have a small handful of Filcos, along with a couple others (keycool, ducky, etc). For whatever reason, the Filco definitely feels more solid and just.. better built? It's almost the most expensive of the lot as well. You get what you pay for, imo! I've never had any buyer's remorse about any of the Filcos that I've purchased. The others I have, on occasion.
Something that the Filcos have, that I prefer, are the costar stabilizers. I think they feel much better than cherry mx stabilizers (I'm not sure which the QFR uses).
Offline lilky
« Reply #44 on: Wed, 16 October 2013, 18:31:53 »
I have a Filco MJ2 Ninja in browns and my friend has one in blues. I've extensively tried boards from Leopold, Ducky, Razer, Das, CM, and KBT.
If you have the money, buy the Filco. In all honesty, I don't know what it is about them, but their keyboards are just amazing to type on and you can IMMEDIATELY feel the difference between them and any other board. A lot of people have been commenting that CM makes boards from the same OEM and that they are a much cheaper copy of Filco. I own a CM QFR in blues and my friend owns a CM QFR in browns and I can tell you that this is not true at all. While QFRs are amazing, especially for their price, Filcos are still a league above them in terms of build quality, and you can immediately tell when you type on them.
I'm actually in the process of buying my 2nd Filco (in blues) now, and thinking about selling my blue QFR.
Offline bMind
« Reply #45 on: Wed, 16 October 2013, 19:00:40 »
Both are Costar.
in flames we trust..
Offline dante
« Reply #46 on: Wed, 16 October 2013, 20:21:28 »
NCIX Canada charges $35 to US :(  NCIX US / Amazon doesn't have any 87 MX Brown Ninjas
Offline Fragil1ty
  • Abre los ojos.
« Reply #47 on: Thu, 17 October 2013, 02:03:38 »
I think I'll definitely try one out in the future, I didn't find this UK filco supplier until I had already purchased a Keycool from Qtan (again), so I guess I'll just have to wait and see what happens. >.>
你搞砸了
Offline bMind
« Reply #48 on: Thu, 17 October 2013, 07:16:35 »
em..they do?
http://www.amazon.com/Filco-Majestouch-2-Tenkeyless-FKBN87M-EFB2/dp/B004ZJPSGI
Offline dante
« Reply #49 on: Thu, 17 October 2013, 07:40:33 »
em..they do?
Ok .. Amazon does but they are not $149.99.  The cheapest one on your list was $165 + $30 shipping.
