Author Topic: BLUETOOTH FILCO ON EBAY  (Read 2860 times)
Offline ValerieV
« on: Fri, 11 October 2013, 18:13:48 »
HOLY COW! I just bought mine. I can't believe it. This is exactly what i have been waiting for.  :D
Re: BLUETOOTH FILCO ON EBAY
« Reply #1 on: Fri, 11 October 2013, 18:17:27 »
The Minila? Hmm...
Offline ValerieV
« Reply #2 on: Fri, 11 October 2013, 18:20:03 »
What do you think? This is great news that now mechanical keyboards like Filco are going bluetooth!!
« Reply #3 on: Fri, 11 October 2013, 18:21:43 »
I don't know if I would trust a seller in Hong Kong with only 92% positive feedback. That's the only reason I couldn't pull the trigger.
Offline ValerieV
« Reply #4 on: Fri, 11 October 2013, 18:25:16 »
I did. I will post once i get it if there are any problems.
Offline unicomp_uc
  • Interboardal Love
« Reply #5 on: Fri, 11 October 2013, 18:52:14 »
I have the non-Bluetooth with Brown's... really solid board. The layout is very well thought out. I've personally found the small right shift and backspace are really easily adapted too and the function layer arrows are smarter and more natural... that and the function layer backspace make this a keyboard that rarely has you leaving home row. I switched the backspace to prepare for my incoming hhkb.
If you can live with the abs key caps, it's a great, solid board.
Realforce 87U Silent (work) | HHKB Pro 2 | Filco Minila browns | Unicomp Ultra Classic
Offline phetto
  • HHKB JP
« Reply #6 on: Fri, 11 October 2013, 18:54:35 »
Very tempted. Are these made by costar Taiwan and using costar stabilizers?
Offline ValerieV
« Reply #7 on: Fri, 11 October 2013, 19:16:04 »
I used to have the wired version and i believe it uses costar stabilizers but i am not positive. I can't wait. If this one works out okay i may get the cherry mx brown as well. I order the cherry mx blue version.  :thumb:
Offline Pacifist
  • on hiatus
« Reply #8 on: Fri, 11 October 2013, 19:17:24 »
Link?
Offline terran5992
  • One With The Cup Rubber
« Reply #9 on: Fri, 11 October 2013, 19:27:13 »
Bluetooth= Battery powered
Offline phetto
  • HHKB JP
« Reply #10 on: Fri, 11 October 2013, 19:48:36 »
Anyone know how long range BT usually has? My computer is about 10 metres from my sofa, will it work?
Offline ValerieV
« Reply #11 on: Fri, 11 October 2013, 20:11:01 »
Link?
I am having a little problem linking it. Just do a search on ebay for Filco bluetooth and it will pop up. Sorry.
Offline spiceBar
    • ChessTiger.com
« Reply #13 on: Fri, 11 October 2013, 20:25:06 »
The Keyboard Company has it on its products list, but not in stock.
I think it's just a matter of contacting them about an ETA.
Offline ValerieV
« Reply #14 on: Fri, 11 October 2013, 21:03:38 »
I guess this model does not have an outlet for a USB cord. That is unfortunate because there are times where you want to save your battery.
Offline meiosis
  • Time
« Reply #15 on: Fri, 11 October 2013, 21:29:12 »
Should work. I can control my bluetooth speakers from like 2 floors up .-.
http://handheldsci.com/kb
This only works with Windows though. I've looked at the firmware it's PITA to make it work well on MAC.
« Last Edit: Fri, 11 October 2013, 21:32:07 by Meiosis »
Keyboards:
Aripeko TKL
Offline spiceBar
    • ChessTiger.com
« Reply #16 on: Sat, 12 October 2013, 00:32:26 »
Good info! Bookmarked! Thanks!
