Author Topic: [IC] Penumbra Key Set (formerly Solarized)  (Read 773795 times)
Offline elllit
Re: [IC] Penumbra Key Set (formerly Solarized)
« Reply #350 on: Sat, 16 November 2013, 17:44:39 »
Got the whole shebang... you are making me poor... now I get it, why some people refer to this forum as the Wallethack O_o
Offline AuRinBei
« Reply #351 on: Mon, 18 November 2013, 09:42:42 »
Sheeeeeeeeeiiiiiit man, only 27 days left? I was hoping it wouldn't start so early. I guess I will have to start selling my blood again. I'm assuming the cable is braided. Also, what is happening with adding keys? I know you said somewhere that you wanted to decide on a set of fixed prices, and then just add in bonuses if enough people order. Is this still the case?
87u || Poker 2
Offline BunnyLake
  • The OG HHKB Master
  • X
« Reply #352 on: Mon, 18 November 2013, 09:49:23 »
its is, i have a post about what im adding in somewhere in the gb thread
Offline ijprest
« Reply #353 on: Mon, 18 November 2013, 12:31:00 »
Just a note about colors:
I did some Lab distance calculations (based on my sampled SP color values and the original Solarized Lab values), and here's what I found:
  • Can't do any better than BED & WCK for the main colors... these are actually very close matches for Solarized $base02 and $base2.
  • GTH is slightly closer to $base1 (dist=5) than the selected GTL (dist=8), but GTH is a little darker, so it's a tough call as to which is better.
  • None of the solarized accent colors have particularly-good matches against SP colors.
  • For $blue, BFN (dist=13) is a slightly better match than BFP (dist=16)
  • For $green, VAV (dist=26) is a slightly better match than VBQ (dist=30)... VAT (dist=21) is the best match, but looks horrible.
  • For $orange, OAS (dist=32) is pretty far off, but all the better matches, such as OB (dist=11) and OAV (dist=12) are pretty close to the red... so OAS might be the best compromise.
Anyway... not really suggesting anything be changed... just felt like crunching the numbers.  :)  The Solarized palette is pretty hard to match against SP colors, so the current selections are pretty good, all things considered.
Offline GeeNDL82
« Reply #354 on: Mon, 18 November 2013, 17:01:36 »
gonna pop this up soon, on a brand new site
gonna need a guinea pig, so if someone is planning on ordering, pm me in the next 30 mins or so to do the first order/test order, and ill give you a 10% discount on your order
damn, i just know it >.< always looking on post on GROUP BUY :)
Vietnam Mechanical Keyboard Club: http://vietnammechkey.com/
« Reply #355 on: Mon, 18 November 2013, 22:04:26 »
Offline jefferai
« Reply #356 on: Thu, 21 November 2013, 22:19:14 »
(deleted; posted in the GB forum instead)
« Last Edit: Fri, 22 November 2013, 03:32:10 by jefferai »
Offline bcredbottle
« Reply #357 on: Fri, 17 April 2015, 14:28:50 »
« Last Edit: Wed, 06 October 2021, 13:59:47 by bcredbottle »
Offline duckness
« Reply #358 on: Fri, 17 April 2015, 21:56:45 »
