Author Topic: frame paint log. help me pick color! Almost done!  (Read 6977 times)
Offline zemp
  • FREE ITENS PLS
« on: Sat, 12 October 2013, 20:57:07 »
gold or chrome?
I'm almost done sanding
edit; chrome gold willnnot work info with red base and gold decals
« Last Edit: Mon, 14 October 2013, 22:10:33 by zemp »
Re: frame paint log. help me pick color!
« Reply #1 on: Sat, 12 October 2013, 21:07:04 »
Chrome.
Offline Tarzan
  • formerly known as Greystoke
« Reply #2 on: Sat, 12 October 2013, 21:18:51 »
Chrome.  With a semi-translucent candy apple red layered over.
Offline zemp
  • FREE ITENS PLS
« Reply #3 on: Sat, 12 October 2013, 21:50:30 »
I'm not that good at painting😊 ^-^
Offline Tarzan
« Reply #4 on: Sat, 12 October 2013, 21:54:48 »
Well, if you're going to try painting a chrome finish, that's pretty ballsy to start with!   :p
Honestly, chrome and any other metallic finish will tend to accentuate any flaws or marks in the underlying surface.  If you're going this route, do try to put down a few coats of primer - wet sanded smooth.
I just had a can of candy apple red sitting on the desk, apologies for the random patin-association!
Offline zemp
  • FREE ITENS PLS
« Reply #5 on: Sat, 12 October 2013, 22:39:30 »
How's my sanding.
Offline zemp
  • FREE ITENS PLS
« Reply #6 on: Sat, 12 October 2013, 22:40:51 »
How's my sanding.
Dark spots is water
« Reply #7 on: Sat, 12 October 2013, 22:47:09 »
#GOLD?
Offline zemp
  • FREE ITENS PLS
« Reply #8 on: Sun, 13 October 2013, 18:55:12 »
Chrome will not work.  So now I use gloss red and gold acents/stripe
Offline zemp
  • FREE ITENS PLS
« Reply #9 on: Sun, 13 October 2013, 19:17:36 »
White primer done
Should I white base and gold stripes  keep red base and gold stripes s?
Offline zemp
  • FREE ITENS PLS
« Reply #10 on: Sun, 13 October 2013, 23:19:25 »
Red it's still wet I tookbpic at night
Offline Photoelectric
« Reply #11 on: Mon, 14 October 2013, 00:38:07 »
White primer done
This is your project to get creative on :). Whatever looks good to You!
« Last Edit: Mon, 14 October 2013, 00:40:05 by Photoelectric »
Offline zemp
  • FREE ITENS PLS
« Reply #12 on: Mon, 14 October 2013, 20:08:19 »
My paint go to thick on one side  :(
Offline zemp
  • FREE ITENS PLS
Re: frame paint log. help me pick color! Almost done!
« Reply #13 on: Mon, 14 October 2013, 22:14:14 »
Red with some grain. So its anti finger print finger
Its more glossy on the back  sides
« Reply #14 on: Mon, 14 October 2013, 22:16:17 »
Looking good :)  Red's always a good choice!
Offline zemp
  • FREE ITENS PLS
« Reply #15 on: Mon, 14 October 2013, 22:22:27 »
Thanks! Im going to add an gold stripes thjs weekend.
Offline zemp
  • FREE ITENS PLS
« Reply #16 on: Mon, 14 October 2013, 22:41:40 »
The contest thing... i'm not sure how the contest works, i've read the threads.
Please explain in 10 year old format
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #17 on: Tue, 15 October 2013, 00:11:26 »
make stuff!!!!!!1111111oneoeneoneoeneoeneoneoeneoeneo
« Reply #18 on: Tue, 15 October 2013, 00:26:48 »
1. Make stuff.
2. ?
3. Profit!
Offline zemp
  • FREE ITENS PLS
« Reply #19 on: Tue, 15 October 2013, 17:38:24 »
1. Make stuff.
2. ?
3. Profit!
That ddnt make much sense.
Whats the profit part?
 :confused:
« Reply #20 on: Tue, 15 October 2013, 17:42:37 »
1. Make stuff.
2. ?
3. Profit!
 :confused:
1. Fun
2. Fancy decorated keyboard
3. Fun?
« Reply #21 on: Tue, 15 October 2013, 18:17:16 »
1. Make stuff.
2. ?
3. Profit!
 :confused:
Er, unicorns?
Offline zemp
  • FREE ITENS PLS
« Reply #22 on: Wed, 16 October 2013, 01:01:01 »
I'm planing to trade my red quickfire and try some colors with gold.
Il post agian when I revive my gold paint and then somehow get cases
Offline mkawa
« Reply #23 on: Thu, 17 October 2013, 20:24:40 »
i have sent you instructions on how to order them from the cm-store zemp. let me know if you need further help :)
Offline cherpalla
« Reply #24 on: Tue, 29 October 2013, 10:24:38 »
 :thumb: Looking good!
c h e r
