Author Topic: Blackstorm stealth keyboard switch  (Read 5323 times)
Offline Jvx104
« on: Sun, 13 October 2013, 14:15:39 »
Hello,
I've just joined the community and stumbled upon this keyboard in the largest Finish computer retailer. Seems to be an inhouse brand, as I can't seem to find the keyboard anywhere else, but the picture about the switches intrigued me. It's not explained anywhere what they are, and I've never seen them. Does anyone know these switches?
You can see a diagram of the switches in the fourth product picture.
http://www.verkkokauppa.com/fi/product/18669/dmbgx/Blackstorm-Stealth-pelinappaimisto#tab-product-reviews
Offline gameaholic
Re: Blackstorm stealth keyboard switch
« Reply #1 on: Sun, 13 October 2013, 14:24:58 »
Looks like a rubber dome to me.
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline ch_123
« Reply #2 on: Sun, 13 October 2013, 14:26:06 »
Welcome to Geekhack!
They look like rubber dome with sliders to me, which were relatively common back in the 80s and 90s. The 'special rubber' may mean that they are built to higher quality/tolerances than standard rubber dome keyboards, and the sliders may help give a nicer feel, but that's about it.
« Last Edit: Sun, 13 October 2013, 14:27:55 by ch_123 »
Offline Jvx104
« Reply #3 on: Sun, 13 October 2013, 14:34:42 »
Yeah seems like a small improvement over the normal keycap on the left, nothing major. Still a bit intrigued about this as I've not seen it anywhere else. Maybe just a marketing gimmick?  Maybe just the support plate could have achieved the same effect. On the reviews someone was saying they remind him of a keytronic.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #4 on: Sun, 13 October 2013, 15:17:35 »
Yeah seems like rubber dome with removable keycap and slider, and maybe a thicker rubber.
However if they can manage to get it to feel like Topre then it might be worth it.  Because Topre is basically rubber dome (oneness with cup rubber) with removable keycap and slider and coiled spring.
Though the name really bugs me, it sounds like a rip off of Blackwidow + CM Storm.
Offline Jvx104
« Reply #5 on: Mon, 14 October 2013, 06:40:35 »
Its named as it is because the inhouse gaming computer line they have is named blackstorm. For example I have the blackstorm mouse and gotta say for its price its one of the best I've had.
Offline mauri
« Reply #6 on: Mon, 14 October 2013, 07:54:31 »
And the inhouse gaming computer line derives from the gaming cafe, or the cafe is sponsored by blackstorm, tho I swear the cafe was first, well..  who knows
It has POM-switches, whatever they are and PBT caps.
« Last Edit: Mon, 14 October 2013, 07:57:14 by mauri »
I AM BABAR KING OF THE ELEPHANTS
« Reply #7 on: Mon, 14 October 2013, 11:58:06 »
POM is a type of plastic, which sometimes goes by the trade name, "delrin". If it sues POM in the switch construction (in the sliders perhaps?) it could account for POM being used to refer to the switch.
There is some evidence (on the spacebar underside) that cherry uses the same molds for their PBT and POM keycaps, so if it says "PBT on it, it's not always for sure PBT. I would recommend a density / friction test.
Offline Jvx104
« Reply #8 on: Tue, 15 October 2013, 06:51:49 »
So basically the same as a normal rubber dome, maybe a bit firmer. I'll tell you more if they have any on display when I visit the store.
