Author Topic: Poker II Accessories?  (Read 2800 times)
Offline Kian
  • Business Man
« on: Sun, 13 October 2013, 21:57:53 »
Hi guys,
     I just received my Poker II the other day and it being my fourth mechanical keyboard, it is my absolute favorite and I will be sticking to it. I'm looking for some more accessories to order for it. I have already ordered some White PBT Keycaps since I really like to keep things clean and simple. I'm looking for a few things or maybe even suggestions! Is there a place where I can order a fitting wrist rest for the Poker II? Possibly even a travel case for it?
Poker II with Cherry MX Browns
Re: Poker II Accessories?
« Reply #1 on: Sun, 13 October 2013, 22:00:08 »
Might contact techkeys see if they have any poker cases left.
Offline Steven
  • Formerly lowyatguy
« Reply #3 on: Mon, 14 October 2013, 02:00:02 »
The best accessories for ur poker u will be some aluminum cases  :D
LF: Duck Mini V1 aka Duck Poker Case
http://geekhack.org/index.php?topic=49840.0
KMAC Happy | Hammer Poker Titanium & Silver | Leopold FC660M | FILCO TKL White | Ducky 9008S2 Pink | Ducky 9008G2 Pro Dye Sub | Ducky YOTD
Offline concept73
« Reply #4 on: Mon, 14 October 2013, 02:29:33 »
I'm getting a case from Pexon here:
http://geekhack.org/index.php?topic=47776.0
But i would like to see some carry bags for 60% keyboards.
Poker 2 with reds
Soon to be a JD40 with reds
Offline ctbear
Offline saturnotaku
« Reply #6 on: Thu, 17 October 2013, 21:10:23 »
As far as carrying cases go, the one for the HHKB should fit. It's a bit larger, but this one will work as well.
Offline terran5992
  • One With The Cup Rubber
« Reply #7 on: Thu, 17 October 2013, 21:32:44 »
I think that the hhkb and the poker have different dimensions, might not fit
Offline saturnotaku
« Reply #8 on: Thu, 17 October 2013, 21:42:20 »
HHKB is 11.6 x 4.3 x 1.6 inches while the Poker II is 11.6 x 4.01 x 1.5 inches. The Poker should have no problem fitting into the HHKB case.
