Author Topic: Backlit with Costar stabilizers?  (Read 13335 times)
Offline dcarwin
« on: Tue, 15 October 2013, 12:59:43 »
New to mech boards. My new work keyboard is a Quickfire Rapid (browns). I'm very happy with it.  I needed back-lighting for playing games the in the dark and my old Saitek isn't bright enough to see any more, so I just bought a Ducky Star 3 (mx browns).
I was sorely bummed when I hit the Enter key. Hard to press and mushy.  I did not know there'd be so much difference for my little pinky[1]. I know it's my own fault for not test-driving Cherry stabilizers vs Costar, so I'll stop whining. I greased the stabilizer but not much change.
Question: Is there a (mx brown) keyboard out there with Costar stabilizers that has back lighting?  Maybe a board with unlit stabilized keys - i.e. only small-keys are lit?
Thanks
[1]don't care much about the space bar, I smash that thing
Offline esoomenona
  • Gnillort?
Re: Backlit with Costar stabilizers?
« Reply #1 on: Tue, 15 October 2013, 13:09:12 »
Are you familiar with soldering?
Offline esoomenona
  • Gnillort?
« Reply #2 on: Tue, 15 October 2013, 13:19:18 »
I ask because of this: http://geekhack.org/index.php?topic=34759.0
Doing this modification to the stabilizers completely changes the feel of them, for the positive.
« Reply #3 on: Tue, 15 October 2013, 13:22:07 »
moose, if you've got a board that uses pcb mount cherry stabilisers then that will work a treat (eg older poker/pure models).. but I don't know of a TKL board that uses pcb mount stabilisers. That mod does nothing to the feel of plate mount cherry stabs, i've tried it.
Offline esoomenona
  • Gnillort?
« Reply #4 on: Tue, 15 October 2013, 13:24:51 »
I don't see why it wouldn't do anything to the feel of plate mount stabs, aside from them sitting higher up off the PCB. alaric confirms in that thread that the inserts are the same on both PCB and plate mount.
But then I've never tried it myself, so...
« Reply #5 on: Tue, 15 October 2013, 13:26:12 »
On pcb mount the bottom of the stems actually hit the PCB. Those parts you cut off dampen the landing. On plate mount I'm pretty sure they're constantly suspended by the wire, and don't come in contact with anything (i could be wrong though).. Anyway, the mod definitely did nothing for me on plate mount :/ although I would like to hear from other people who've tried it too.
« Last Edit: Tue, 15 October 2013, 13:28:02 by Photekq »
Offline dcarwin
« Reply #6 on: Tue, 15 October 2013, 13:29:18 »
I did read that thread when I got the board, and it looked interesting. I can solder, but per Photekq, is the mod applicable to this board?
« Reply #7 on: Tue, 15 October 2013, 13:29:49 »
I'll re-try it now and get back to you.. uno momento por favor.
Offline esoomenona
  • Gnillort?
« Reply #8 on: Tue, 15 October 2013, 13:30:53 »
I suppose there's always finding a Universal TKL plate, installing that, then putting Costar stabs on?
Other than that, I can't really think of one. The Code was close, though it had Clears... but that's sold out.
Offline esoomenona
  • Gnillort?
« Reply #9 on: Tue, 15 October 2013, 13:33:43 »
How do you feel about 60%?
Offline Moosecraft
  • HHKB Pro
« Reply #10 on: Tue, 15 October 2013, 13:38:11 »
Razer blackwidow stealth edition? Even though it's frowned upon around here I think it is the only backlit costar board afaik.
« Reply #11 on: Tue, 15 October 2013, 13:38:58 »
The mod actually does work.. I think I must've tried it previously when it wasn't mounted on a PCB. I tried it mounted on a PCB now and it feels nice.
If I were you OP I would go for the mod (maybe some lube on it at the same time) ;)
Offline dcarwin
« Reply #12 on: Tue, 15 October 2013, 13:42:49 »
I don't follow you on what 60% means. (?)
« Reply #13 on: Tue, 15 October 2013, 13:44:15 »
It's the size of the keyboard. 100% - full board, 80% - tenkeyless, 60% is just the alphanumerics, no arrows, no f-row etc.
Offline esoomenona
  • Gnillort?
« Reply #14 on: Tue, 15 October 2013, 13:45:58 »
http://farm9.staticflickr.com/8311/7895277966_e66e9d8b60_b.jpg
PCB mounted (no plate) Cherry stabs (easy to clip mod), backlit, and you can find in Browns with different color lighting, I'm sure.
Offline esoomenona
  • Gnillort?
« Reply #15 on: Tue, 15 October 2013, 13:47:28 »
That's good to know. Thanks for checking again, Photekq. I had a feeling the results would be similar. Maybe not as pronounced as with PCB mount, but at least noticeable.
And a good suggestion on the lubing!
« Reply #16 on: Tue, 15 October 2013, 13:51:39 »
No worries. It's made me feel a bit better. I was dreading having to use plate mounted stabs on my phantom.. Once you go PCB you never go back.. but I think I can live with these modded plate mounts :D
Offline Danule
« Reply #17 on: Tue, 15 October 2013, 14:52:47 »
WASD Code.  Should be coming out in browns supposedly.
45g Brown Brown Blue
Offline dcarwin
« Reply #18 on: Tue, 15 October 2013, 15:55:19 »
Thanks, Watching for this. Something to look forward to, especially if I beef my ducky.
Offline MKULTRA
  • telling it how it is
« Reply #19 on: Tue, 15 October 2013, 16:03:03 »
Most Korean customs with a plate your PCB mounted stabs.
Offline Dreamre
    • kbdlife
« Reply #20 on: Wed, 16 October 2013, 12:13:42 »
So when you remove the stabilizers, do you need to desolder that one switch in between?
« Reply #21 on: Wed, 16 October 2013, 12:21:30 »
On the spacebar you can kinda do it without desoldering but it's tricky. On the other stabilised keys it's practically impossible without desoldering.
Offline esoomenona
  • Gnillort?
« Reply #22 on: Wed, 16 October 2013, 12:23:42 »
I bet it's not so impossible. I wish I had a keyboard with plate mount Cherry stabs to experiment with...
Offline Dreamre
    • kbdlife
« Reply #23 on: Wed, 16 October 2013, 12:25:48 »
Thanks for the quick reply! Also, how do you remove the stabilizers on a plate mounted keyboard? Sorry for asking this noob question if this question has been asked before :P.
Offline Dreamre
    • kbdlife
« Reply #24 on: Thu, 17 October 2013, 20:09:58 »
I just did the clip mod and it makes a world of a difference.
All you need to do is to desolder that one switch. Now it feels like costars :0!
« Reply #25 on: Thu, 17 October 2013, 20:14:25 »
Great to hear that it worked! Enjoy!
Offline Dreamre
    • kbdlife
« Reply #26 on: Thu, 17 October 2013, 22:26:35 »
Thanks for the help :D! Much appreciated.
Offline stancato9
« Reply #27 on: Tue, 19 November 2013, 12:32:04 »
Sorry for the necro bump but I need help. On my plate mount cherry stab inserts, there are no extra pieces to cut off. I'm really confused as to how to do this mod.. Can someone help me out? I see a few people in this thread have done it with plate mounted stabs. Thanks.
Poker 2 - MX Red
« Reply #28 on: Tue, 19 November 2013, 12:59:32 »
Post a photo?
« Reply #29 on: Tue, 19 November 2013, 13:07:33 »
(From a photekq PM)
Your inserts probably look like that?
Make them look like this.
Since you have a plate mount housing, they'll probably fall out since the plate mount housings are different from the PCB mount ones (Pic from Ripster). So then on the bottom of your plate where the stabilizer housings are, tape a bit of cardboard/plastic to cover the bottom hole:
(From a photekq PM)
I think the Cherry PCB mounted stabilizer clip mod works because you clip off the little legs (shown in the DT post) and the insert is free to hit down on the PCB. Since you have a plate mounted housing, it has nothing to hit down on so the taped cardboard/plastic cover gives the stabilizer something to hit again to feel solid. Otherwise it will just fall out and feel loose.
Edited for clarity.
« Last Edit: Tue, 19 November 2013, 13:09:42 by CPTBadAss »
« Reply #30 on: Tue, 19 November 2013, 13:10:55 »
CPT, i have tried the clipping mod on plate mount stabilisers, with no kind of cardboard etc. All I did was clip it, nothing else. It greatly improved the feel, just like with pcb mount. I think that even on plate mount the bottom of the inserts hit the PCB, so clipping has the same effect.
Also, can't believe you still have those photos  :))
« Reply #31 on: Tue, 19 November 2013, 13:12:29 »
I swear I saw a picture of a mod with plate mounted stabs where they taped something on the bottom...I could be wrong but I'm going to go with my (poor) memory. You can always just try it without taping anything first stancato9. If it works like photekq says, then everything's cool. If not, tape something on the bottom.
« Last Edit: Tue, 19 November 2013, 13:14:15 by CPTBadAss »
Offline stancato9
« Reply #32 on: Tue, 19 November 2013, 13:37:52 »
Thanks for the responses. My stabs look nothing like the ones in any of those pics.. I need to get some pictures up later on so it will be easier.
Poker 2 - MX Red
« Reply #33 on: Tue, 19 November 2013, 13:39:52 »
(From here)
Do they look like that by chance?
Offline stancato9
« Reply #34 on: Tue, 19 November 2013, 13:41:29 »
No no. That's costar :p
Poker 2 - MX Red
« Reply #35 on: Tue, 19 November 2013, 13:42:29 »
You know those pictures are of the UNDERSIDE of the stabilisers, right? You have to actually remove them from the board before you can modify them.
Offline stancato9
« Reply #36 on: Tue, 19 November 2013, 13:43:34 »
Yes. I have spare stabilizers on hand. They are not on the board.
Poker 2 - MX Red
« Reply #37 on: Tue, 19 November 2013, 13:44:52 »
Right.. very strange that they look nothing alike. Will await pictures.
Offline stancato9
« Reply #38 on: Tue, 19 November 2013, 13:45:48 »
I'm specifically talking about the insert pieces that go into the housing. They don't have the little legs or anything.
Poker 2 - MX Red
« Reply #39 on: Tue, 19 November 2013, 13:49:05 »
Yeah I think we should just wait for pictures before guessing anymore.
Offline stancato9
« Reply #40 on: Tue, 19 November 2013, 13:50:25 »
Yeah I'll get them up later. I only have my sister's iPhone cam to take pics with so hopefully it can capture the details.  :blank:
Poker 2 - MX Red
Offline stancato9
« Reply #41 on: Tue, 19 November 2013, 14:31:30 »
Made an album with a few pics. Maybe I'm just uneducated or blind but they look different.
http://imgur.com/a/O14nd
The pics are rotated badly. Let me know if you want me to rotate and reupload. Thanks.
Poker 2 - MX Red
« Reply #42 on: Tue, 19 November 2013, 14:34:42 »
Hmm, odd. They have the same insert as the old PCB mount stabilisers I have from a Nixdorf PCB. You won't need to modify them. They'll feel like clipped ones right off the bat.
Offline stancato9
« Reply #43 on: Tue, 19 November 2013, 14:37:37 »
I got these from Whiskytango so it's possible that they could be. I'm glad you validated it though. I thought I was going crazy not being able to do a simple mod.  :p
Poker 2 - MX Red
« Reply #44 on: Tue, 19 November 2013, 14:38:22 »
That explains it then. They will be from an old WYSE board.
Offline stancato9
« Reply #45 on: Tue, 19 November 2013, 14:39:58 »
Looks like I won't have to do anything than. Awesome.  :thumb:
Poker 2 - MX Red
« Reply #46 on: Tue, 19 November 2013, 14:43:02 »
Hooray for happy endings XD
« Reply #47 on: Tue, 19 November 2013, 14:46:52 »
Haha I started to ask where you got them! Glad it's sorted.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #48 on: Tue, 19 November 2013, 20:40:44 »
Maxkeyboard has a backlit board on costar stabs.  :p It's on their nighthawk series.
Offline terran5992
  • One With The Cup Rubber
« Reply #49 on: Tue, 19 November 2013, 21:19:09 »
Code keyboards as well
