Author Topic: MKC Keypuller...? Not working well?  (Read 2539 times)
Offline xyeLz
« on: Tue, 15 October 2013, 18:20:31 »
Anyone here purchase the MKC keypuller? I just got mine and it doesn't really seem to fit very well around the keys. It's somewhat of a struggle. Should this be a seamless process...?
ReΛlforce 87U - Capacitive (45g), ReΛlforce 103UB - Capacitive (Variable)
Offline bazemk1979
Re: MKC Keypuller...? Not working well?
« Reply #1 on: Tue, 15 October 2013, 18:47:00 »
mkc with the metal handle? I use mine and its very good keycap puller
« Reply #2 on: Tue, 15 October 2013, 19:33:05 »
Looks the same basic design as most wire keycap pullers.
It took me a little while to get used to it after using the plastic ring ones supplied with many keyboards.
Now I'm not sure I could use a plastic one again.
Fitting it over some of the larger modifiers can be a bit daunting.
« Reply #3 on: Tue, 15 October 2013, 20:31:55 »
Thus the need for two of them.
To the OP mine matches up fine to other metal wire pullers
Offline PointyFox
« Reply #4 on: Tue, 15 October 2013, 20:36:00 »
I hate wire pullers except for pulling odd shaped or large keys.  They take about 5x longer to use than the ring pullers.
« Reply #5 on: Tue, 15 October 2013, 20:38:16 »
I tend to remove the 1x keys around the longer keys, then use my fingers mid-position along the longer keys to gently coax them off.  Especially the space bar.
Offline tbc
« Reply #6 on: Tue, 15 October 2013, 21:51:47 »
LOVE the wire pullers; the ring pullers keep scratching the keycaps.  Do other people just have better technique or do they just not care about scratches on the sides?
« Reply #7 on: Tue, 15 October 2013, 22:02:30 »
Probably don't care, or just don't notice, the scratches.
Using the wire one was awkward at first, but now much easier and quicker.  And it doesn't keep slipping off.
Offline Hyde
  • White Tofu Extraordinaire
« Reply #8 on: Wed, 16 October 2013, 08:45:38 »
http://geekhack.org/index.php?topic=46376.0
Read topic #2.  I suspect this is what the OP did.
Offline terran5992
  • One With The Cup Rubber
« Reply #9 on: Wed, 16 October 2013, 09:06:40 »
Its works pretty well for me
