Author Topic: Filco Blank Keycaps  (Read 3124 times)
Offline Capraza
Filco Blank Keycaps
« on: Wed, 16 October 2013, 12:09:58 »
Hi Geekhack,
A couple of months ago I bought a filco majestouch tenkeyless keyboard and now I want to buy some blank keycaps.
I have been looking for a while but can't find a lot of compatible keycaps since I use the ISO layout. The only official
set of keycaps I found was on this site: http://www.keyboardco.com/product/blank-black-filco-105-key-keyset.asp
I read about people who got keycaps on wasdkeyboards.com but I'm not sure whether or not they are the right profile.
A while back i ordered an esc keycap from qwerkeys.co.uk but the profile of the key was totally different than
my original keys. (see picture)
Additionally I'm a little bit worried about the plastic quality of they keys, the key I ordered was made from a glossy type
of plastic while the original filco ones are matt.
I hope you guys have some exciting options :p
Thanks.
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: Filco Blank Keycaps
« Reply #1 on: Wed, 16 October 2013, 12:26:13 »
WASD keys are the exact same as stock Filco.
Offline Capraza
« Reply #2 on: Wed, 16 October 2013, 14:39:18 »
Thanks Ivan, is the quality of the plastic comparable to the filco's?
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #3 on: Wed, 16 October 2013, 16:45:07 »
If you are in canada (and maybe the US) you can get blank filco brand caps from ncix.
http://www.ncix.ca/products/?sku=82732&vpn=FKB104%2F87NP&manufacture=Filco
edit: sorry the original link did not work from my phone...
« Last Edit: Wed, 16 October 2013, 16:59:57 by swill »
« Reply #4 on: Thu, 17 October 2013, 10:51:48 »
Yes, same crappy quality.
