Author Topic: Question about Poker II programming.  (Read 1448 times)
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« on: Wed, 16 October 2013, 16:07:34 »
I never liked Poker for its layout of the modifier keys around space bar. Recently I found out Poker II allows hardware programming and this actually rang the bell. Question to Poker II owners: Does it allow reprogramming bottom row of the keys? I'd like to totally change the positions of Win, Alt, PM and FN keys.
Re: Question about Poker II programming.
« Reply #1 on: Wed, 16 October 2013, 16:09:05 »
You can't change FN key without harware modding.
Offline saturnotaku
« Reply #2 on: Wed, 16 October 2013, 16:09:33 »
Nor the Pn key.
Offline czarek
    • FalbaTech
« Reply #3 on: Wed, 16 October 2013, 16:13:17 »
Thanks for your quick replies guys. It makes this keyboard just as useless as the Poker I or Pure to me then :)
Offline mr. rampage
« Reply #4 on: Wed, 16 October 2013, 16:14:35 »
You can turn the WIN key to a FN key, but that's about it. And in order to run any of the hardware programs, you have to hold down the PN key + the trigger. :(
What I ended up doing was map all the WIN-key shortcuts and moved the WIN key to the PN key that way. It's ugly... but it works. For some reason, why I use the keyboard at home instead of at work, the bindings don't work.
