Author Topic: Black Space Invader Switches at a Good Price  (Read 3774 times)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline dante
Re: Black Space Invader Switches at a Good Price
« Reply #1 on: Mon, 28 October 2013, 10:18:19 »
Your find did not go unnoticed  :-*
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #2 on: Mon, 28 October 2013, 10:23:55 »
good for you!
i have the same exact board and trust me you will love it and the switches
very light tactile, click
if you try to remove a cap BE CAREFUL as the spring from the switch will spring and usually pop out, so do not lose it ;)
do me a favor...........after you get get it let us know what you think either way
Offline dante
« Reply #3 on: Mon, 28 October 2013, 10:40:35 »
Will do.  I also scored this one: http://www.ebay.com/itm/350905431635
I look forward to trying them out! :D
Offline do_Og@n
« Reply #4 on: Wed, 30 October 2013, 00:14:08 »
Curse you and your NMB with windows keys keyboard. I would love one of those!
Offline ComradeSniper
  • HHKB Pro
« Reply #5 on: Wed, 30 October 2013, 00:48:59 »
Nice find, black space invaders are some of my favorite vintage switches. Those boards look like they're in nice shape, so the switches should be fairly smooth.
Offline dante
« Reply #6 on: Sat, 02 November 2013, 16:55:29 »
Here are the pics (you've already seen)
http://geekhack.org/index.php?topic=33130.msg1100000#msg1100000
I received the boards in today.  I like them a lot!  I'm about to run out the door to Fry's to pick up a AT/PS2 for the DTK.
I'd have to say the Space Invaders are tied with the IBM Model M2 as my favorite clicky keyboards of all time.   My wallet is very thankful that neither are very popular.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #7 on: Sun, 03 November 2013, 15:59:32 »
 :thumb:
i'm right there with you..................i do not own a topre, but i love my space invaders as well
congrats
« Reply #8 on: Fri, 08 November 2013, 15:53:00 »
So, now I am the owner of the DTK black space invaders board.
I gave it a good cleaning, and I like it a lot, although it may not be as crisp as I had hoped.
My question is: did I screw up putting the spacebar back on, or is it just REALLY heavy?
I see that it is a completely different switch (bright blue) but is it supposed to be approximately twice as heavy as the others?
Not necessarily a problem, I don't mind a heavy spacebar, but this seems excessive.
- D Trump 2026-10-24
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #9 on: Fri, 08 November 2013, 16:14:22 »
mine is heavier as well after i checked.........
http://deskthority.net/wiki/NMB_Hi-Tek
  • HHKB Pro
« Reply #10 on: Fri, 08 November 2013, 17:16:08 »
That's how mine is as well. You can always switch out the spring if it gets to be an issue. I have trouble typing with a spacebar that heavy.
« Reply #11 on: Fri, 08 November 2013, 18:02:20 »
Why do space invaders always have the same keycaps?
« Reply #12 on: Fri, 08 November 2013, 19:05:43 »
The switches are very strange and there have to be a variety of mounting nubs built into the caps.
Mine has REALLY thick nice PBT caps.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #13 on: Fri, 08 November 2013, 23:24:20 »
right............which whenever i try to remove the cap i seem to always pull off the top of the as well because of the nubs. of course everything goes back when putting in place, but still.
you are right they are pretty darn thick :thumb:
switches are different, kind of light clicky- but i like them
« Reply #14 on: Sat, 09 November 2013, 12:52:51 »
These are tricky. I have an IBM key puller that has a flat plastic wide piece with a very small lip. I found that using this puller sideways produced the best results by far. That is, hook under the side of the cap rather than top or bottom, and roll toward the center rather than pulling straight up.
PS - I switched the spacebar spring with Scroll Lock and it is much better now!
