Author Topic: KeyCaps For My TKL Shine 3!  (Read 4505 times)
Offline Abn
« on: Sat, 19 October 2013, 17:49:19 »
So i preordered my shine 3 and it should be here this week, and I was wondering if anyone had any cool ideas of what I should do keycap wise with it !
I am open to any suggestions and pictures of your own!
-Abn
Noppoo Choc Mini Reds | Ducky Shine 3 TKL Browns | Topre Realforce 87U 45gram
Re: KeyCaps For My TKL Shine 3!
« Reply #1 on: Sat, 19 October 2013, 19:33:53 »
Enjoy it as it is for a few weeks to let yourself become accustomed to it.
As for backlight-friendly keycap sets, there are not many of those around, mainly those made by Ducky which you can pick up from a few places.
For non-backlight-friendly keycaps, the Ducky has a standard layout so almost any standard set should fit.
Offline Abn
« Reply #2 on: Sat, 19 October 2013, 20:27:46 »
Ya hmm, I guess ill just stay with the regular keycaps... Im a sad panda.
Edit... I found some I want, does anyone know if there are any like this that will fit a Ducky ? :D
http://www.maxkeyboard.com/max-universal-black-translucent-mechanical-keyboard-keycap-set.html
Edit 2: It does fit ducky and I am pretty sure it also has cherry style modifiers! So this is the set I will be getting :D
« Last Edit: Sat, 19 October 2013, 20:39:39 by Abn »
« Reply #3 on: Sat, 19 October 2013, 21:01:29 »
Those ones will give you a different look to the standard Ducky keycaps.
Instead of each letter lighting up when the backlighting is on, the legends are printed on the side of the keycaps, and the backlighting just makes the top of the key glow a bit.
Offline terran5992
  • One With The Cup Rubber
« Reply #4 on: Sat, 19 October 2013, 21:02:31 »
You could try to find a different colored set of backlit keys
« Reply #5 on: Sat, 19 October 2013, 21:58:44 »
What do you mean, terran5
What do you mean? The colour usually comes from the LEDs.
There are coloured transparent keycaps though. There are also opaque keycaps but that are not very thick, so the light shows through them anyway (but you get to see the struts inside)
You could use different colours of such keycaps on the board if it has white backlighting.
« Reply #6 on: Sat, 19 October 2013, 22:55:43 »
Or, with white LEDs (mainly), you can get small plastic caps that fit over the LEDs under the keycaps to change the colours that shine through.
Offline BrockSamson
« Reply #7 on: Sun, 20 October 2013, 20:42:40 »
What do they call those little plastic caps anyways? Do they work well? Know where to get them?
Offline xecut
« Reply #8 on: Sun, 20 October 2013, 22:24:17 »
Get a Snake keycap from geekfeng ! LOL
since Shine3 kinda symbolises Year of the snake.  :))
Or maybe, get a set of PBT DoubleShot keycaps. Looks pretty awesome i reckon.
Topre Realforce 87U 10th Anniversary Edition | Topre Realforce 87U White Silent | KBT Race | KBT Poker ii | Filco Majestouch Pink
