Author Topic: Replacement keycaps for FC660M  (Read 2261 times)
Offline swill
  • builder & enabler
    • swillkb.com
« on: Sun, 20 October 2013, 01:44:16 »
If I want to get thick PBT replacement keycaps for the FC660M, do they even exist?  I know the spacebar is wonky, both shift keys are the same size and the modifier keys are a bit unique.
Offline kgrad5
Re: Replacement keycaps for FC660M
« Reply #1 on: Wed, 23 October 2013, 21:42:45 »
Pretty sure I have seen specific sets meant for fc660m on ebay. I would also ask qtan. Bunnylake is also having a group buy right now targetted at 60% keyboards which might fit the 660m.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #2 on: Wed, 23 October 2013, 21:46:48 »
Ya, I don't think bunny's will have the leopold spacebar.  And not to be a snob, but I don't want ABS if I can avoid it...
