Author Topic: IBM RGB keys?  (Read 3300 times)
Offline Shadovved
  • King of Stickers (and GBs)
IBM RGB keys?
« on: Sun, 20 October 2013, 04:56:28 »
It issnt frequent I get to ask a noob question :p
I'll like to know whether the IBM RGB printed keys are dyesubbed...... cos they seem slicker and smoother than my stock Model M keys :confused:
Thanks bros ;D for indulging me in a moment of noobness :thumb:
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
Re: IBM RGB keys?
« Reply #1 on: Sun, 20 October 2013, 06:01:37 »
they are dyesub (when we are talking about the ones from unicomp)
Offline Shadovved
Re: IBM RGB keys?
« Reply #2 on: Sun, 20 October 2013, 06:52:31 »
The ones from Unicomp, yeap :D
Cos they feel SOOOOOOOOOOO different  :cool:
Thanks man! I can rub my fingers on it now :))
Re: IBM RGB keys?
« Reply #3 on: Sun, 20 October 2013, 08:05:29 »
Unicomp keys are decidedly different. Probably a different plastic compound, because the equipment is the same.
You can dye keys pretty successfully.
- D Trump 2026-10-24
Offline Shadovved
Re: IBM RGB keys?
« Reply #4 on: Sun, 20 October 2013, 10:38:14 »
But are they as durable as the IBM ones?
I hope they dont shine quicker or something
Re: IBM RGB keys?
« Reply #5 on: Mon, 21 October 2013, 06:58:58 »
Mine are holding up pretty well after half a year of use, but you can start to see where my fingers usually hit, if the light is right.
Don't fret, accept what you can get. Your choices for IBM caps are extremely limited compared to Cherry.
A shame, a disgrace that is.
Offline Shadovved
Re: IBM RGB keys?
« Reply #6 on: Mon, 21 October 2013, 07:00:03 »
Better than my Filco I guess.......it feels slicky like every month, only takes a bubble bath to get rid of it  :-X
Re: IBM RGB keys?
« Reply #7 on: Tue, 22 October 2013, 04:27:37 »
We need more Topre and more BS keycaps, customs and complete sets, in general.
And if they do wear out (eventually), at least you can get some more.
There is not even RGB for Topre, unless you buy a complete set of each colour and just use the modifiers.
