Author Topic: Dome Model M adding [ and ; ?  (Read 1438 times)
Offline M-88
« on: Mon, 21 October 2013, 07:39:51 »
I have a few dome style Model Ms. I hooked one of them up yesterday and randomly, it would add [ or ; in whatever text box the curser was sitting.
I did not have to be tying, it would automatically add them. However, every time I hit the P key, it would always insert one or the other.
Anyone have any ideas on troubleshooting this?
Offline terran5992
  • One With The Cup Rubber
Re: Dome Model M adding [ and ; ?
« Reply #1 on: Mon, 21 October 2013, 08:08:32 »
0.o never had that problem before
Offline Hellmark
« Reply #2 on: Mon, 21 October 2013, 11:55:57 »
I've had that happen with rubber dome keyboards before. Pretty much dead at that point.
« Reply #3 on: Mon, 21 October 2013, 13:38:27 »
you should bolt mod it and take a look at the membrane.
Fortunately the plate, membrane and barrel frame (as well as the controller, case and LED's) are the same as the buckling spring version, so they are all replaceable
If you like I'll take pictures from when I bolt mod mine.
